Hi friends, I’ll be picking up a 5090 end of the month and want to build a new system for it. I only use it for gaming so high frames and quality is the aim.
Given the following requirements, which parts would you choose?
Budget not a huge concern, but standard bang for buck applies (e.g. No need to spend over the odds for a ~2% type of benefit)
Air cooling
I’ll have:
I need:
I've been out of the loop for several years and so your guidance would be really appreciated, thank you!
Air cooling
I’ll have:
- RTX 5090 FE (hopefully)
I need:
- Case (ATX, good ventilation)
- Mobo (bluetooth and wifi required, does spending more here net much gaming benefit?)
- CPU (and cooler)
- RAM (32gb is fine, but would 64gb make much difference to games?)
- NVMe (1TB is fine)
- PSU
