Saw this on another forum
"I think I may have found leaked pricing for the AIB, 5070Ti, 5080 and 5090 in the UK.
If you go to the **** website and search for one of the above and scroll down to the price you can see the lowest price and you can move the slider to reveal or hide cards. Granted these could all just be placeholders.
5070Ti - £889.00 (ASUS Prime)
5080 - £1078.00 (MSI Ventus)
5090 - £2099.00 (Palit Gamerock)"
Is the regular FG on 40 series still going to be run though the optical flow accelerator or is that going be moving to software when DLSS 4.0 hits?Sure why not, but you see the problem with that statement is that Nvidia made the mistake of publishing the tensor core performance of the new cards and the 4090 has better tensor performance than the 5070 and matches the 5070ti. So how is it that MFG 4x can run on a 5070 when it has less tensor performance than a 4090... and no doubt the 5060 is going to have even less tensor performance, probably less than a 4080.
Nvidias misleading lies are easy to pick apart
Flip Metering
The display engine has been updated with flip metering logic that allows for much more consistent frame pacing for Multiple Frame Generation and Frame Generation on 50 series.
Yeah meant MFG. But in all fairness looking at the minimum FPS the most demanding games run at, MFG isn't really something that is needed at highest end GPUs on a 4k 120hz screen.DLSS4 is coming to all the RTX cards, it’s the multi-frame-gen (MFG) that’s exclusive to the 50 series. But perhaps that’s what you meant.
Maybe Nvidia should make some handhelds or something. Put MFG to real use.
Knowing Nintendo it'll be a stretch if it even has DLSS and a 1080p screenThe Switch 2 could use frame generation
Jesus wept5070Ti - £889.00 (ASUS Prime)
Not even he can save us from Uncle Jensen.Jesus wept![]()
Yup, there's rumors this is gonna be one of the paperiest launches yet lol, some retailers in NA aren't even gonna get any 5090s in stock, I expect there will be like 10-50 cards per each SKU like the 3080 was, which is why these retailers can pull these pre-built only shenanigansOK Ive decided, this is what I'm gonna do on release day:
Try to buy a FE 5090
Or bag a AMP Extreme 5090
Or a 5090 Suprim
Or a Asus Strix, (not Tuf or Astral)
Last thing is I'll just buy another 4090 and use that for 6 months before trying again
But the missing cards that I also like that I cant see is:
EVGA FTW 5090
Galax Hall Of Fame 5090
Oh and guess what, some retailers are now guaranteeing you a 5080/90 only if you buy a prebuilt system hahaha
Curious to see how much this helps. O find the frame pacing of FG in some fames truely awful. Lethal combo when you add in the extra latency.Reading this post in r/nvidia:
Make of that what you will.
Or a 5090 Suprim
EVGA FTW 5090
Strix only exists on 5070ti and below. Your only choice for 5080/5090 is Tuf/Astral.Or a Asus Strix, (not Tuf or Astral)
