Surely that’s meant to be Kg not grams?
It's meant to be milligrams. Asus are using mostly Unobtainium to fabricate their cards this generation.
The 5090FE is pulling more power and is smaller than the 4090 so some extra noise should be expected. However, if it's annoying during normal (gaming) operation, that's still a problem that makes it a less impressive design.
My biggest question/issue with the design is that surely it's basically incompatible with CPU air coolers now as it's just going to blast them with hot air?
Tbh I’m not even sure how necessary it is for GPUs to sit below 70 these days.
Fan noise is a distraction. Some say they don’t care as they game with headphones on, well great! Meanwhile, the rest of us like high end gaming in quiet and peace and not generating 70+ heat in the process.This appears to be Nvidia's attitude with the 50-series.
It's actually very hard to get a 4090FE above 70C at all in a well-ventilated case. I wonder if Nvidia have decided that the cooler was over-engineered and that an increase in temps and noise was acceptable.
I don't doubt the new cooler design is more efficient but is it efficient enough to offset the increase in power consumption and reduction in cooler volume, thus maintaining the same levels of temps/noise as a 4090? I seriously doubt it.
In all likelihood its going to be loud, the fans will be compensating for the smaller and slimmer design that they gave the card heatsink. There is less space for the heat to dissipate.I like to think that Nvidia would not release an FE card that sounds like a jet engine at its rated max power usage. That would be a huge design flaw after the FE cards getting so good the past two generations. Only a couple more days until we find out.
I agree that it will be louder than the 4090 FE (physics will do what physics does), but I don’t think it will be horrendous. Maybe i have taken too many copium tablets recently. Anyway, as each day goes by, my desire to purchase a 5090 falls lower and lower.In all likelihood its going to be loud, the fans will be compensating for the smaller and slimmer design that they gave the card heatsink. There is less space for the heat to dissipate.
Your definition of horrendous may be very different to someone elses'.I agree that it will be louder than the 4090 FE (physics will do what physics does), but I don’t think it will be horrendous. Maybe i have taken too many copium tablets recently. Anyway, as each day goes by, my desire to purchase a 5090 falls lower and lower.
I'm not sure if it'll be much louder than then 4090FE though. Nvidia aren't stupid, they'll have spent time working out the balance between noise/thermals/performance and it's really good to see some innovation in the heatsink design approach. Double flow through with no air being blocked might really mean that the fans can spin at the same speed as on the 4090 but in a slimmer format at the same temperatures.In all likelihood its going to be loud, the fans will be compensating for the smaller and slimmer design that they gave the card heatsink. There is less space for the heat to dissipate.
I wonder if the 5090 was intended to be a 575w card from the start, or if they found the performance they were getting at 450w wasn't enough and decided to push the card/cooler as hard as they could.to squeeze better numbers out of it.I like to think that Nvidia would not release an FE card that sounds like a jet engine at its rated max power usage. That would be a huge design flaw after the FE cards getting so good the past two generations. Only a couple more days until we find out.
Given it is the same node as the 40 series, give or take, my guess is that from the start they knew they would have to juice the 5090 to the max to get additional performance from it.I wonder if the 5090 was intended to be a 575w card from the start, or if they found the performance they were getting at 450w wasn't enough and decided to push the card/cooler as hard as they could.to squeeze better numbers out of it.
100% they have had to push the power to get a reasonable uplift, a 20% uplift on a $2000 card looks terrible but 35% looks ok.I wonder if the 5090 was intended to be a 575w card from the start, or if they found the performance they were getting at 450w wasn't enough and decided to push the card/cooler as hard as they could.to squeeze better numbers out of it.
Well that is debatable100% they have had to push the power to get a reasonable uplift, a 20% uplift on a $2000 card looks terrible but 35% looks ok.
It's actually one of my main deciders in a new card. I much prefer gaming without a headset in anything other than competative FPS.Fan noise is a distraction. Some say they don’t care as they game with headphones on, well great! Meanwhile, the rest of us like high end gaming in quiet and peace and not generating 70+ heat in the process.
Larger fans are more quiet purely because they don't spin as fast as small ones to push same air volume. 120mm or 150mm fans at 3000rpm will be loud, very loud. Providing the 4090fe is same height as 5090, the fans are the same in both cards. And 4090 f3 fan size is 115x115x15mmThe 5090 FE has larger fans than the 4090FE, so even though it's 15mm slimmer the larger fans should compensate because they move more air at the same RPM.
Larger fans tends to be quieter as well.
