Enjoy your 5090s, chaps. I’ll be waiting for this!
Dual 12 pin 800w
that's a monsterPlease remember that any mention of competitors, hinting at competitors or offering to provide details of competitors will result in an account suspension. The full rules can be found under the 'Terms and Rules' link in the bottom right corner of your screen. Just don't mention competitors in any way, shape or form and you'll be OK.
that's a monsterSo quite cheap compared to some things!The RTX 5090 costs $1 for every gram
That'll be a year away anyway... But damn man, 800W xD I'm wondering if the 5090 will be flashable to unlock those extra cores though, I'm wondering if the single 12vhpwr connector can supply enough juice for them...
That's bonkers if true, if anything, nvidia needs to put some cards between the 5080 and 5090, there is a huge chasm between them.
Depends, if your pushing silicon limits, colder is better. Ryzen 2000 and 3000 series had throttle points around 85 and I believe my 5800X3D is the same. No clue about 7000 series or 9000 series or whatever SKU intel is on now.It depends on the case I suppose.
New cpus have high thermal limits. There is no real harm caused by a modern CPU chugging away in the 70s or even the 80s.
Tbh I’m not even sure how necessary it is for GPUs to sit below 70 these days.
this will be itSo…. Anyone seen any 6090 rumours yet?
https://videocardz.com/newz/alleged...ower-and-32gb-32gbps-memory-has-been-picturedI can’t see Nvidia going any higher the for 6090… It’s not like a watch or handbag where you can show it off.£2k plus for a GPU is ABSOLUTELY MENTAL.
Just thought I'd throw that in there.
I'm one of those weirdos who, you know, likes results to go with my expensive functional hardware. Whether it's unicorn pink or Master Chief green with five fidget spinners attached, it makes no difference to me.You don’t like dog food shaped boxes? What is wrong with you?
Even if they did make that, it would cost upwards of 2500 and be at best about 10% faster than a 5090Dual 12 pin 800wthat's a monster
Spot on. There’s no games out there just now that are good enough to justify spending anywhere close to that. Maybe for mixed usage it may be decent for some but purely for gaming it’s bonkers.£2k plus for a GPU is ABSOLUTELY MENTAL.
I would agree to an extent. But I'm likely to get one if the overall cost of the upgrade after selling my 4090 is circa 600 or less. Way I look at it, theres a roughly 2 year release cadence. If it costs me 300 ish a year to stay at the top of GPU performance, I can stomache that as I use my PC for work in the day and games in the evening.Spot on. There’s no games out there just now that are good enough to justify spending anywhere close to that. Maybe for mixed usage it may be decent for some but purely for gaming it’s bonkers.
Well it won’t be cheaper that’s for sure. If anything, they will just keep the MSRP at 2k, but AIB cards will start at 3k. 2080 Ti flashback…I can’t see Nvidia going any higher the for 6090… It’s not like a watch or handbag where you can show it off.
£600 or less? So you sold your 4090 for £2,000?I would agree to an extent. But I'm likely to get one if the overall cost of the upgrade after selling my 4090 is circa 600 or less. Way I look at it, theres a roughly 2 year release cadence. If it costs me 300 ish a year to stay at the top of GPU performance, I can stomache that as I use my PC for work in the day and games in the evening.
