Do I need to use ethernet for best speeds?
Will it mazx out my WiFi before the 900?
Well i am no expert but what ethernet port is available on your PC motherboard ? mine for instance is 2.5GbE some are only 1Gbe.Yeah but I've seen 2.5 gigabit advertised. I only have 2 devices. What would need to pipe all that in to 1 pc.
Why do you need 2.5Gb to a single PC especially if you only have 2 devicesYeah but I've seen 2.5 gigabit advertised. I only have 2 devices. What would need to pipe all that in to 1 pc.
Yeah but I've seen 2.5 gigabit advertised. ........... What would need to pipe all that in to 1 pc.
A very good reason?
That aside, you need a router that can handle it (if not using ISP's one), appropriate network cabling/port of cable to the PC and a 2.5 supporting NIC on the PC's motherboard. If the PC doesn't have that then an add-in 2.5GbE card in a pice slot.
Yeh, on mine, I only get the full (1GB) on cable, wifi about half the speed.
Are you using 3rd party router?Well at the moment it takes about 13 minutes to download 100 gig. Some steam games are massive.
Anyway new issue. The apps on my phone arnt working right. Bbc weather. Playstation apps, just spinning circles. Any ideas? I connected to the 5ghz wifi my phone supports and messenger, chrome etc work on the phone just certain apps don't.
What phone? My Pixels have always been so iffy on 5Ghz
HmmmIt's a tp link thing.
Phone is a samsung s something
