Spec Check - General Gaming PC
27 Jan 2025
ipswich
Been about 15 years since I last built a PC........
Looking to build a PC to Run a wide range of Games inc Driving Sims, RTS, multiplayer shooters (Old Tac-Ops Player).... Do like the look of games like Cyber Punk
VR - Meta Quest 3
Any issues with the below Spec??
AMD Rzen 5 9600x
Corsair Vengeance RGB 32GB (2X16GB) DDR5 PC5-48000C30 6000MHz Dual Channel
GigaByte Radeon RX 7900XT
MSI MAG X670E Tomahawk
WD BLack SN7100 2TB NVME OS / Games storage
WD Blue SN580 - Backup / General Storage
MSI MAG AB50GL 850W PSU
Lian Li O11 Vision Compact Black
Lian Li HydroShift LCD 360S AIO CPU Cooler 360mm - Black - Plan is replace Fans with UNISL LCD Fans
Lian Li UNI SL WIRELESS LCD RGB 120mm Fan Triple Pack - Black see above
Lian Li UNI SL WIRELESS RGB 120mm Reverse Flow Fan Triple Pack - Black Intake fans on fitted to base
Lian Li UNI SL WIRELESS LCD RGB 120mm Fan - Black Fitted to rear behind CPU
Thanks
Edders
The 9600x is barely faster, as in 1%, than a 7600x, save some money there.
Do you need anything specific on the X670E now or in the future ? If not then its overkill for that level of CPU.
Thanks for the fast response
I was able to get the 7900 XT and the X670E for £710 which I thought was a good enough deal to spend the extra. Maybe its wasn't??
This isn't entirely correct.
It hovers depending on usage between 1% to 30%.
For gaming when you average things out it does come close to 1% but you really need to decide on what you're buying the chip for in terms of software:
There's a 19% improvement for Asseto Corsa for example, and this is with a launch review.
It seems the chips really like SIMS, and the OP apparently enjoys them.
Whether this is worth the extra £40-50 is up to the buyer, for most probably not, if I was buying for racing sims I'd absolutely spend the extra.
good point. I'd happened to watch the HUB review about 10mins prior and the 1% stuck in my brain.
Thanks All
Again I think I was Lucky and was able get the CPU for £205
Good point on the Bios - this was one area I was most worried about as I don't have access to other older CP to do the downgrade
I have all the parts apart from the Memory and the Lian Li stuff - on Pre-Order with Overclockers
Still have a ability to return these parts if there's a glaring issue or better option
Once again Many Thanks
Edders
Thanks All
The MSI tomahawk has bios flash button so you can update the bios without the need for another CPU.
This will help you.
