Gigabyte X860E Aorus Pro
2 Feb 2025
Liverpool
Hi all,
I am just about to start my new build with a 9800X3D and I noticed my motherboard has a rev 1.0 BIOS. On Gigabyte's website it says my CPU will be supported with a F1 BIOS. Is this the same as rev 1.0 or will I need to update my BIOS to get it to work with my CPU?
Thanks for reading!
Should be the same mate you should be good to go if you've only just got the board chances are you'll be on a later bios anyway
Ah brilliant, thank you for your help!
I know with Gigabyte's software you can update your BIOS software so I'll probably do that rather than use BIOS Flashback as I'm terrified I'll do something wrong and brick my mobo lol!
