That makes no sense.I think that fusion could potentially be relatively cheap in part because it's technically difficult.
Kyshtym was caused by a combination of crappy design caused by ignorance (the USSR was using information they'd stolen from the USA, partial information they partially understood) and a downright horrific level of negligence.
Chernobyl was mainly caused by crappy design. Multiple instances of crappy design piled on top of each other. And then the reactor was used for too long and in ways it wasn't designed for and by people not properly trained for the job.
Fukushima Daiichi was mainly caused by crappy design. In particular, two pieces of it. The backup power generation for the cooling system was in the wrong place and the sea wall wasn't high enough. If either or both of those things were done properly, the meltdown wouldn't have happened. That can be shown by what happened at Fukushima Oniichi. Same general location, same design, built at the same time in the same way, hit by the same earthquake and the same tsunami in about the same way. But the sea wall was higher. So the backup cooling system didn't flood despite being in the wrong place and nothing bad happened there.
None of the infamous nuclear disasters could happen with a modern design.
I was once involved in a focus group for pollster company that was chosen for an electricity/nuclear adjacency bias. And even this supposed more knowledgeable focus group need what you wrote explaining to them. This was about 20 years ago and people who worked in related industries and had lived the previous 20+ years within a few miles of tokamaks and near old decommissioned nuclear piles didn't understand the relative risks of the two nuclears.Not when it's completely stripped out of all context, as you did. As it was, as part of that post, it made sense.
Fission is technically easy in the sense that it just requires enough suitable material close enough together and it happens automatically and creates a self-sustaining runaway chain reaction. Since it's like that, using it as a power station requires constant careful control. Which requires design and engineering to achieve and maintain that control. And failsafes. And backups. And backups to the backups. That's where a large part of the cost is. Then there's the waste, which is another large part of the cost.
Fusion is technically difficult (in conditions achievable on Earth). Because of that, it can't happen automatically and it can't create a self-sustaining runaway chain reaction. It also has far, far less material inside the reactor at any time. Because of those things (which are a result of the technical difficulty of fusion), using it in a power station doesn't carry the same risks and therefore doesn't require the same level of expense for containment, failsafes and backups. You still need those things, but to a far lesser (and therefore far cheaper) extent. So it has the potential to be relatively cheap. If it can be made to work in a practical sense, with net energy output.
Failsafes may be reduced compared to a fission plant, but the engineering required to produce and contain the plasma are orders of magnitude greater than what is required in a fission reactor.Not when it's completely stripped out of all context, as you did. As it was, as part of that post, it made sense.
You're basically summarising his point. What's yours?Failsafes may be reduced compared to a fission plant, but the engineering required to produce and contain the plasma are orders of magnitude greater than what is required in a fission reactor.
"The initial budget was close to €6 billion, but the total price of construction and operations is projected to be from €18 to €22 billion; other estimates place the total cost between $45 billion and $65 billion, though these figures are disputed by ITER."ITER, which as an experimental reactor is going to be very expensive, is currently (from what I can see) going to come in at lower cost than Sizewell C.
That fusion power isn't going to be cheap, as some have claimed.You're basically summarising his point. What's yours?
nevermindall the meltdowns were mainly caused by crappy designs? or the fact they were really generating nuclear fuel and electricity was just a by product (like the UK one)
nevermindNo it doesn't and no we haven't.
Chernobyl was the worst case scenario in pretty much every way. It didn't destroy the planet. It couldn't destroy the planet. Chernobyl did far less harm than the worst hydroelectric power failures.
The number of deaths directly and definitely caused by the Chernobyl meltdown is 31.
The number of deaths almost certainly caused by the Chernobyl meltdown is 60.
The number of deaths probably partially caused by the Chernobyl meltdown is about 4000.
The number of deaths directly and definitely caused by the Banqiao failure is about 250,000.
We've been extremely unlucky in all the meltdowns. The fact they happened at all required bad luck, bad design and at least some degree of negligence.
nevermindKyshtym was caused by a combination of crappy design caused by ignorance (the USSR was using information they'd stolen from the USA, partial information they partially understood) and a downright horrific level of negligence.
That's what they always say, until it happens again.
Chernobyl was pretty close to a realistic worst case scenario though... theoretically if there had been no attempts to put the fires out and generally contain the situation then a lot more radiation would have been released, but even in the Soviet Union I'm not sure that could ever have been allowed. Turns out that the corium wasn't going to melt through everything and get to the water table even without the miners' hard work. And although the water tanks under the reactor were a concern last I heard was that most modern analysis doesn't think there was much risk of a large explosion even if they had been full of water and corium had dropped in. In fact some corium did drop into some of them before they could be emptied and not much happened. The TV show and it's talk of 2 megaton explosions was essentially complete nonsense.Chernobyl wasnt the worse case scenario, many people died to prevent the worst case scenario from happening. There's loads of material on it out there you can go read or look into.
Fission reactions create fission products... often highly radioactive and some with very long half-lives.
Fusion does not. The byproduct of Hydrogen Fusion is Helium.
And since we can't exactly get fision right ATM how do we know when fusion is finally cracked it will be right?
Chernobyl wasnt the worse case scenario, many people died to prevent the worst case scenario from happening. There's loads of material on it out there you can go read or look into. its also still ongoing right now. Did you get your death toll from some Russia website?
The death count official figures are crap and you know it. Scientists put the death toll in the first few months or so at 30,000+
, Russia has covered up the real death count figures.
Chernoblyl isn't over and done with people are still dying from radiation. check out a few of the others too there's lets see another 1 in russia that was covered up can't recall the name of where it's at now
and Fukushima to name 2 of the top of my head (Japan are still trying to convince the population to move back into eradiated land),
Whitehall almost happened too. Yes bad luck and bad design, who's to say the same won't happen with fusion? Its elusive meaning we are still yet to figure it out, do you think that means it will be done right from the get go? Humans lie to make mistakes as a learning curve.
Don't the escaping neutrons create radioactive by-products in the surrounding mechanisms?.
That is the trade off why the most realistic chance for viable Fusion, ITER, is around $65billion and still only a research prototype.Failsafes may be reduced compared to a fission plant, but the engineering required to produce and contain the plasma are orders of magnitude greater than what is required in a fission reactor.
I read an interesting article suggesting that a design similar to ITER would be able to burn high radioactive trans-uranics as part of it's normal fusion operation. So even is they never economically pan out they are a possible route to reducing high level waste inventories.That is the trade off why the most realistic chance for viable Fusion, ITER, is around $65billion and still only a research prototype.
Just like fission, they will suffer from the lack of scale economics and the significant build time and thus ROI will make them prohibitive.
Renewables and BESS will continue to become exponentially cheaper.
