VR Dev rig for £2,000-£3,000
27 Nov 2003
Hi all,
I need a rig for making VR software, can anyone help me spec?
- Not sure AMD vs Intel, I thought AMD was better value but is this still true for non-gaming use?
- For this price I was looking at a 5080, but given the current lack of supply, would I be better off just getting a 4080 or something (Need this within the next 4-6 weeks)
- I think a 1TB M.2 and a 2TB Secondary SSD should be enough
- Would prefer as small form factor as possible as I will need to move this rig from time to time (Just to a building across the street)
Thanks!
They are in short supply too, I'm afraid, so it likely won't help you get one faster.
It depends on budget and use case. The Core Ultra CPUs (15th gen equivalent) actually aren't that bad for productivity and you can get good deals on 12th gen. If you're going ITX, a lot of the value depends on the motherboard, since if you want a high-end one with certain features, they can be very expensive and difficult to find (in stock). I'd recommend MATX over ITX, since it gives you more options.
If you're going SFF, note the size restrictions (GPU length and number of slots) on your chosen case, since most 5080/5090s are whoppers.
My basket at OcUK:
Total: £2,564.81 (includes delivery: £11.98)​
That's great, thanks.
That case is actually really well sized for what I need.
couple question - when you say Intel options aren't that bad for productivity, how close are they to Ryzen 9s?
Is that CPU cooler going to be enough? I was expecting to spend 60-100 on one for something like this.
Cheers again
In the launch reviews their performance was all over the place. They're more consistent now with the updates, but there are still some circumstances they are unusually slow.
That said, for multithreaded productivity the 245K performs somewhere around the 7900/7900X and is generally faster than the 9700X.
The 9900X will beat it.
In TPU's review, the average power consumption in apps was less than 100 watts and the multithreaded power less than 150 watts, so a decent cheap air cooler like the freezer 36 or peerless assassin/phantom spirit can definitely handle this CPU.
Same one as you suggested for mine but just wondering about fan noise from this CPU fan?.
At modest load, e.g. single or lightly threaded or gaming, a decent tower cooler like those mentioned will be near silent with these CPUs (possibly with some fan curve changes to curb ramp up/down when the CPU boosts).
At full multithreaded load, you will hear it, but up to 150 watts this should be fine. If you go beyond that point regularly (or plan on buying a CPU that does), it will get noisy and I'd recommend looking at an AIO instead.
What about games at 4k?.
