ah crap, I remember right at the start you had two accountsmy discord account doesn't exist for some reason
all i did was re format my PC
Anyone tried ACC with the new DLSS? Assuming it was working right and I'm not misremembering how badly ACC runs, DLSS ultra performance looked better than quality used to look
Try it out for tthe novelty if like me, you haven't tried running ACC since 1944
After playing with ACC I went back to iracing though and everything just looks right, like the cars are the right size and crystal clear and you can see clearly off into the distance
Yea but historically, DLSS quality looks like **** when the assets are next to your eyeballs. It's definitely improved, but I don't quite agree with it being near iracing or ams2 or AC to be honest. I probably prefer LMU as well. I'll have to experiment a bit though. It's really annoying trying to get the ACC sliders balancedI dont have ACC, can you run it in DLSS in VR?
it needs a bit more work yetHas anyone tried acevo in vr yet?
ThanksYeah it's playable but needs work
Thanks
Gutted that technical issues ruined my race tonight. No idea what happened, but my wheel buttons basically stopped working completely. To fix it had to open Sim Hub, which put AMS2 in the background, and for some reason this then makes my FPS go down to about 5. It finally came back but then my brake was so sensitive it was impossible to drive. I'm getting a bit frustrated with this game.
We've all had issues at some point mate, stick with it. Once you get sorted you'll be fine, although it is very frustrating. My wireless mouse has suddenly decided it doesn't want to play nice, so I've had to order a wired one.
There's always something......
good to have you with us though, and hope the next race goes a bit better for you
£5 Thrustmaster and my £100 Thrustmaster kit
