Underboss
- 20 Oct 2002
- Oxfordshire / Bucks
Posted this in the GPU section
basically at 100% the results are comparaable between the cards.35 mins. Can anyone give a tl;dr? Watched the 1st few mins, seems as though he likes the 5090.
Cheersbasically at 100% the results are comparaable between the cards.
but as soon as the res starts increasing i.e. 200/300/400 the 5090 does a much better job of maintaining averables at higher frame rate.
higher bandwidth shows its performance increase.
this time stamp sort of shows exampleof descrepencys (red matter 2)
or Kayak VR
slightly differant config display order
to add : high res headsets = upgrade to 5090Cheers![]()
I wonder if a Q3 is considered a high res headset? Probably not tbh. It's all academic for me now anyway, expecting to pay out all my new gpu money + a good chunk more on something else soon. Still very interesting though, thanks.to add : high res headsets = upgrade to 5090
if your on a 4090, its prob not worth it unless you have the ££ to splash.
if your not on a 4090 already then its worth upgrading.
I'm on a 4080 and a 7800x3d, quest 3, iracing runs so fuggin great it doesn't matter, but for LMU (and maybe the new AC, we'll see) do you guys think CPU or GPU is a better upgrade?
Seeing how ACC has responded to the new DLSS, I wish LMU had it to see if it holds up
