- 15 Mar 2024
- South West
Hi everyone,
I recently upgraded my PC case, the new case has three extra fans. The whole PC now runs a lot louder than it did in the old case and I would like to make it quieter.
The three fans at the front are daisy chained together, then connected to a fan header in the back of the case which is attached to the motherboard. I think this may mean the speed of these fans cant be controlled because the are not attached directly to the mother board?
There are also two fans under the GPU (separate from the three GPU fans) that draw air in, they are also connected to the fan header in the back of the case, which again I assume their speed can not be controlled.
The CPU AIO is connected directly to a Addressable Gen 2 header on the motherboard, the rear exhaust fan is connected to a second Addressable Gen 2 header on the motherboard. Am I right in saying the Addressable Gen 2 headers allow the fans speed to be controlled? or have I got that wrong?
I would like to be able to control the speed of the three fans at the front and the two fans under the GPU, so they are not running at full speed all the time. My GPU temp holds under 50degrees the whole time whilst playing demanding games so I think there is room for the fans to be slowed down a bit?
The motherboard I have is a TUF Gaming X670E - Plus WIFI
Any help would be appreciated.
