- 4 May 2006
- Manchester
Impossible to fix on the FE using software. The 6 pins are all terminated into 1 when it hits the PCB. The card has no idea what each individual pin is doing on the other side of the connector.They need to fix the fact the card is pulling so much more power down just one of the cables instead of evenly distributing the power.
Maybe it can be fixed in a bios update? Unless that power is physically going somewhere it is needed instead of being controlled by programming...
