- 17 Jan 2025
- Somerset
Here's to hoping!Like others have mentioned you’d assume with the RTX 5070 series out soon (20th February iirc) that stock will be available to some degree by then.
Presumably the RTX 5070 and 5070Ti won’t be particularly attractive to scalpers given they’re less performant than a previous generation 4080?
Have you not heard? The 5070 is 4090 performance?
