Solar panels and battery - any real world recommendations?
Very pricey indeed!
I recently had installed
20 x Aiko Neostar 2 455w solar panels
10kW Sigenergy inverter
2 x 8.06 kW Sigenergy batteries
Sigenergy gateway which controls whole home ups backup.
This was all fitted for £13,300
Do you have any shading on the roof? If not then you won't need the Enphase micro inverters which is a big saving.
Who did your installation, and would you recommend them? I'm just down the road from you based on your profile location.
Very pricey indeed!
This is insane value compared to what I paid for mine just a year ago.
it is expensive but they claim the setup would generate more energy which seems to stack up.
However, that’s a lot of 15p’s when you are talking about spending thousands more on a system. Not sure the maths works.
I think the difference is going to be very marginal, and there are always flaws in videos on YouTube that claim they work better.
I saw something the other day about battery prices really crashing hard again.
Forget where but it was something like down another 50% vs about a year ago.
Its why over the last year I have moved from "i should protect my batteries for their 10 year warranty life" to "rinse the hell out of them and if they fail then plan to get new asap"
Also I believe from stuff I have read that they are now saying most LFP degradation is coming from age as opposed to usage, so you may as well work them hard up until the warranty point.
I haven't got any idea on Jan yet, but my system is just over 2 years old and as of end of 2024, I had just passed 30% recovery at 30.1%
Its not an exact science modelling that, but its going to be ballpark reasonable.
I would probably be able to buy a system like mine for 30% less now. So you could say I haven't gained anything, but that cannot carry on forever.
And if it does, roll on the next system :)
good to see you back....
Hi guys, I've recently had a quote from heatable -
Solar panel
15 × 440W REA Power FUSION 2 · REA-HD108N-440
Inverter
15 × Enphase IQ8HC-72-M-INT · 380W
1 × Alpha ESS SMILE-G3-B5 · 5000W
3 × Alpha ESS SMILE-G3-BAT-4.0S · 4kWh
1 x Alpha 7kw Charger
This is £15,200, seems steep to me. I'm interested in some interest free finance options and they are semi local to me.
Any help much appreciated, cheers Chris
I've managed to lock my old account chrisnic0 from 2003 just trying to recover!
Heatalbe are a joke wit their banging on about REA panels, and 380w Micro inverters, and they are forced to install an inverter for the ESS. They are 100% off my recommendation list for people, there are edge cases where it may be better but not £7k better. A Tesla PW3 with more panels will cost less, and be waaaaay better over all.
We used Cahill renewables for the install, They’re based in Kent and Essex.
The sales staff were pretty good and were open to tailoring the system to my needs not just a standard this is what we fit install. The actual installers were great and listened to where I wanted the components put and how I wanted the cables run through the house. After care has let the side down slightly with the office being super slow getting my handover pack out to me.
Overall I would recommend them. Cost wise it was 2k cheaper for the same kit from another installer I was originally going to use (skylar solar).
I see Octopus are advertising their solar / battery install service a lot at the moment but do they offer any advantage over other installs? They also offer battery only installs which might work out if they allow cheap overnight recharging.
From what I remember other posters saying, is Octopus solar installs are expensive, and subbed out. You'll be better off finding a good local installer.
Yes, you can get onto Octopus Go without an EV, as they don't ask, and charging a battery overnight looks just like an EV. If you got room for panels, fit as many as possible.
Do Octopus actually require any proof of an EV to join Go? They've asked me what car/charger I have but not sure if they probe more than that!
I told them I had a home battery storage system and needed to charge overnight, they were happy with that.(no EV)
Been on GO over 3 years now.
That's not THAT big, particularly for his energy consumption. That said, it was a bit silly to to locate them on the floor next to some hedges and then complain they get shaded. If they absolutely cant be raised, they should have had optimisers or micro inverters.
I saw in the comment he was getting flamed for his consumption, particularly his heat pump and I actually agree with him, he seems to be getting excellent efficiency out of it, particularly given how old it is. His running a flow temp of 30C-35C to heat the house and garages, that's perfect. its 22kw which sounds big but he is also heating over 400m2 of which some of that is garages. The heated outdoor swimming pool heat pump will absolutely be drinking the electric here in the UK.
