NVIDIA RTX 50 SERIES - (PRE)ORDER DISCUSSION **NO COMPETITOR HINTING**
yep nothing new to me , old news ;)
They made H++ spec for sockets, but the cable can still melt if either the single 12V rail on the FE got some quality issue or if the PSU is still only H+ spec. I think that's why it is recommended to buy a PCIE 5.1 spec PSU and use OEM PSU 12Vx6 cable, otherwise use the GPU cable splitting into 3x8 pin or 4x8 pin PCIe connectors.
yeah replaced with H+ as at the time H++ had just been announced.
Which is stupid because the GPUs come with x4 8 pin adapters anyway! That would make you think that would be ok even if you had the other newer options, which I for one don’t.
Sorry.what do you mean?
I mean the melting connector issue is nothing new to me considering my 4090 melted it's plug a good year and half ago , the fact the 5090 is still melting is no surprise to me as they are feeding the same about of power through a rubbish connector that's had a mild revision that clearly isn't working. The solution to this is the 90 series need 2 of these 12VHPWR/ 12v-2x6 connectors fitted to the card so the load can be easily balanced rather than trying to fit it all through one but as we only have cards with one it is what it is and will have to work with what we got .
There’s a Gainward 5090 available now on OcUK if anyone is interested.
Edit: ah, you can’t put it in your basket on the product page. Not that I was intending on it.
So despite that, why did you go ahead and grabbed a 5090?
How was it esily sorted? you had to send your card all the way to germany if i am not mistaken who then had to mod it?
Also:
It was easily sorted by me taking it out the pc putting it in a box having DHL collect it from my house then deliver it to Kris Fix in Germany who fitted a brand new plug so not modifying it just repair it , he then put it back in said box and sent it back to me in all less then 7 days and cost me nothing. Had it not gone to him then Nvida themselves were more than willing to have it back as I spoke to them also which from experience would have been 10 days turn around but I wanted to keep the card as explained so sent it to Germany. I was so happy with the service I received i would have no issues paying out my own pocket had that been the case . Nvidia will not leave anyone in the **** over this and will have you a new GPU replacement no problem at all if you want to rma the thing.
Who are kriss fix?
Give us some content so we can't all do the same if we need to
Who are kriss fix?
He is a repair shop in Germany that specialises in precision repair work on GPU and CPU :
He was my first port of call when i knocked all the capacitors off my 14900KS when delidding it , he had it back as good as new :D
