Hi All,
I recently got a new 3500X series case and would like to vertically mount my GPU, which I know the case supports, with the addition purchase of a PCIe riser cable / card which even the manual mentions.
It is however not clear which riser cable / card I need to get. My system is PCIe 4.0, therefore looking at Corsair’s products line, that leaves one of the following options:
1.) Premium PCIe 4.0 x16 Extension Cable, 300mm (CC-9310001-WW)
2.) 2500 Series Vertical GPU Mount Kit - Black (CC-8900706)
3.) 6500 Series Vertical GPU Mount Kit (CC-8900717)
My assumption is that the 1st might be recommended, though in my opinion is too long. Other people on forums suggested a more fitting length of 150-200mm, which both the latter fall into this category, but I do not know if the spacing between the standoff mounts are compatible with my 3500. I understand that if I were to purchase any of the latter two, that I will not make use of the PCIe slot cage (PCIe riser cable / card only).
Can anyone confirm supportability and advise? Thank you in advance.
Kind regards,
CTV
Kind regards,
CTV
