Caporegime
- 7 Apr 2008
- Lorville - Hurston
No competitionNative gaming
The 5070 is going to be slower than the 4070 Super looking at the spec
How on Earth did we get here
Native gaming
Having a look at this thread for some discussion on undervolting a 5090 and the minimal performance loss. https://old.reddit.com/r/nvidia/comments/1irplq5/my_results_of_undervolting_a_rtx_5090_founders/Apologies if this has been answered already, but do we have any good data yet on how far you can dial down the power limit on the 5090 without losing, say, more than 3% performance? When mine finally does ship, I'd definitely like to run it below 575W (500W or less would be ideal). I've capped my 4090 at 90% power from the day I got it.
True it's designed with too little headroom. The 8-pin to 12V connectors may offer a degree of extra safety, as the PSU side will cap draw from each 8-pin socket.I still don't understand why people weren't more curious about the 8-pin side of the adapters and why *that* end of the included adapters were not what was showing up on Reddit.
It was as if people were plugging in one side of the adapter correctly (the 8-pin side) and then forgetting how to plug in cables when it came time to plug in the other end of the same adapter. (The 12VHPWR side)
The difference between the two sides of the adapter isn't the user plugging in the connectors or their propensity for "error". No, the difference has always been the saftey margin (or lack thereof) on the two different kind of connectors on that adapter.
12VHPWR has been designed within an inch of its life. I think that is the root-cause of this issue.
Are you sure about that? It's still a single 12v rail in the PSU. 150w is only the standard, not the limit of the physics.True it's designed with too little headroom. The 8-pin to 12V connectors may offer a degree of extra safety, as the PSU side will cap draw from each 8-pin socket.
It was nvidia and then a little Dell input, that designed the connector, not the PSU manufacturers.![]()
The Solution to the 12V-2x6 Issue - Hardware Busters
Hardware Busters - The Solution to the 12V-2x6 Issue -hwbusters.com
Oh goody, I sure am looking forward to upgrading my PSU again after already upgrading to an ATX3.1 thinking it would prevent cables melting. Oh and then again to ATX3.2 when Nvidia finally fix it properly.
Here's an idea, how about those same PSU manufacturers go back to the PCI SIG they're part of and fix the godamn broken standard they had a hand in creating?
If this logic is purely in the cable and doesn't require a new PSU, firstly, it would be breaking the spec as the sense pins cannot change during operation. Secondly, there's no way people have the room to fit even more width between their GPU connector and side panel.
Using multiple 8 pins on the PSU side is an improvement (in theory at least) as potentially problems are spread over more strands PLUS the surface area of 2 plugs is much higher which dissipates heat better.Are you sure about that? It's still a single 12v rail in the PSU. 150w is only the standard, not the limit of the physics.
I'm pretty sure they're all part of PCI SIG group. Corsair certainly are.It was nvidia and then a little Dell input, that designed the connector, not the PSU manufacturers.
Me too. At 1440p, I see no reason to upgrade from my 4070S FE for a few more years yet.I might skip this gen. I'm pretty happy with my 4070 super atm
My old eyes don't run at that resolution.3840 x 1600 here
AFAIK (not a sparkie by any means) PSUs also limit the draw of their connectors, separately to single/multi-rail OCP. e.g. my Corsair PSU has a limit of 300w per 8-pin (others are likely lower) which my CableMod cable translates to two pairs of 12v cables. So a 300w limit per two cables; it's not much, but it's some protection.Are you sure about that? It's still a single 12v rail in the PSU. 150w is only the standard, not the limit of the physics.
Native gaming
It's corporate greed.No competition
It would not, a PSU will supply whatever power a device draws right up to the PSU's rated maximum output.True it's designed with too little headroom. The 8-pin to 12V connectors may offer a degree of extra safety, as the PSU side will cap draw from each 8-pin socket.
It says that's what each 8-pin is rated for, it does not say you could not draw more than 300W if you were silly enough to try.my Corsair PSU has a limit of 300w per 8-pin (others are likely lower) which my CableMod cable translates to two pairs of 12v cables. So a 300w limit per two cables; it's not much, but it's some protection.
