With that in mind, I don't think the cable ever can be considered fine, or suitable or good. It has to exist in the real world with cables getting bent, moved, heat cycled, oxidised etc. Let's say magically overnight AIBs start adding shunt resistors to monitor current on each strand and shutting down GPUs*, we'd still have a problem but the problem would be people's GPU's shutting down and them having to replace their cable. Obviously that's way, WAY better than melting.
You have load balancing also but from what I understand, you can't load-balance your way out of a problematic cable.
* I have no idea why the Astral doesn't just shut the card down when it detects a problem.
