- 2 Sep 2007
I’m using an AeroPress at the moment and buying ground coffee. Reading this thread it seems the biggest upgrade for my coffee is to buy a grinder. Would a DF54 be suitable for my AeroPress?
definitely, DF54 is very well regarded although i'd also look at the fellow ode (1 or 2)
Consider hand grinders also if for just you and aeropress, v60 etc.I’m using an AeroPress at the moment and buying ground coffee. Reading this thread it seems the biggest upgrade for my coffee is to buy a grinder. Would a DF54 be suitable for my AeroPress?
Sounds a great grinder.
Having to dial in beans for espresso is 1 reason I have been doing pour overs for the longest time. I just let it steep in the Hario Switch, grind size is much more forgiving.
Recently added the ARO Espresso grind setting dial to my Eureka Mignon specialita and can confirm it works well. I can now change grinds for different brew methods with pretty repeatable results. Should be a standard feature of this grinder I think. It is partially 3D printed but also aluminium on the bits you actually interact with and it looks great too.
Also, anyone notice the Gaggia Classic GT pop up recently? It basically has almost all the features classic owners have been asking for or modding into their machines, and more. However, it’s quite pricey. A lot more than modding your own. But may appeal to some of you? I love my Classic but hate fighting the temp stability. Will have to add a PID some day.
