** Kingdom Come : Deliverance 2 **
The video is super cool
Im 35 hours in and I think i have done all side quests and tasks now.. just got to get the dress and perfume for the miller for the wedding.
Which one did you guys choose to go with the miller or the blacksmith? Does it make a difference? Seems like the miller side might be more amusing. Obviously dont drop any spoilers :)
I went with the miller.
Turns out no matter which you choose, you can still do the other quest at a later date.
Ive done all the blacksmith quest line up to the point where it says 'lets go to the wedding' which i will be at the same point with the miller after this quest, just wondering if it matters which one i go with.
I will be going Blacksmith as I am right there now and it will be the next thing I do.
The only side quest I have left to do from the ones I discovered is the one where you find some dude's armour. Might do that later.
I am sure there are a bunch more side quests, available to do on the map, but fancy doing one main quest and then resume side quests.
I did armour quest last night, it looks awesome especially with tabard you get doing blacksmith quests
  • Like
Reactions: TNA
I don't think I've discovered that side quest yet, somehow - but I've been to a fair few places too so I'm probably dumb.
Just started to play and got totally confused on how to win a ring, to then end up with a sausage.
Playing dice........ Oh my
Does not bode well.
  • Haha
Reactions: TNA
Does not bode well.
Dice has fairly simple rules. As long as you get at least one 1 or 5, you can throw again
Three 1s give you 1000 points, three 4s 400 points etc, you get the picture
It is about risk and reward
You can get a weighted dice in the little cave there.
If you use all your dice up, you can have another turn too. But careful, if you bust, you lose your current and previous rolls.
So, a bust basically means....
if you dont get 1s, 5s, 3 or more of a kind or 1-5, 1-6 or 2-6 in a turn its a bust.
So, you have to score each turn to remain in the game or bust.?
