I posted this over on the network sub, but am hoping someone here might have an alternative answer from the Quest perspective.
I am currently using my Quest 3 in the lounge to access my gaming PC in the garage. The quest connects to a wireless access point in the lounge (wifi 6), and the PC connects to the same access point via a 15m Cat 6 ethernet cable that runs between the garage and the lounge. Playing VR games works flawlessly (been enjoying HL: Alyx in blissful, wireless freedom!)
However, I want to be able to play non-VR games, using the Quest as a virtual screen, and need to be able to use a keyboard and mouse. Essentially I'll have a huge virtual cinema screen infront of me displaying games running on the garage PC. The problem I have is I cannot get the keyboard and mouse to work with the remote PC.
Things I have tried:
I am trying to troubleshoot the external cables - both of them have no issues with passing network signals (internet works flawlessly, and the Quest runs at full speed across it)
Is there a different way to use the KB/Mouse to remotely control to PC?
- Plugging the (logitech) KB/Mouse dongle into the quest directly (works on the quest, but won't interact with the remote PC)
- Using an unpowered USB-ethernet adapter: one each side of the external cable. Doesn't work across the external cable.
- Using a powered USB-ethernet adapter (4 port transmit/receive unit) - again, does not work across the external cable - rated for 60m of ethernet, I'm using less that 15m.
