I was using a Corsair 240 AIO but eventually got fed up with one of the fans RGB being duff and the awful ICUE software. I changed to a Thermalright Assassin 120 for my next build which was a 5800X3D and now use it with my my 9800x3d.
			Thinking of moving away from my EKB 280mm cooler, pump noise is irritating when above 75% speed.
Not sure what air cooler to replace it with though!
Noctua are expensive but they do provide an upgrade path, with conversion kits. So my expensive DC14 would have been unusable but thanks to Am5 kit (which was free) I can now re use it so it was used on a old 1366 system now modern AM5
Thermeltake may be better value for money but if they don't provide adapter kits for future chipsets then you'll have to rebuy £40 coolers everytime.
I did look at noctua, but quite a steep price! Before my AIO I tired a Peerless Assasin but found the fan clips useless as they didn’t hold the fans tight enough so they sagged down and weren’t tight up against the heat sink.
Is the NH-D14 the one to go for?yeah like I said noctua provided upgrade kit,
If they offer Am7/Am8 for my dc14...could get decades out of one cooler.
Looks like they’re quite a premium for similar noise / cooling performance when you look at Thermalright / ID cooling. Will probably go for one of the cheaper options, I don’t think I’ll be upgrading my AM4 for a while.D15 is the new version, there's variants of them depending Intel, AMD or generic to do with offset and also whether the plate is concave, convex or flat.
Not cheap so you'll have to decide whether it's worth the extra.
Here on OcUK Thermalrigh are £17.99 - £39.99 (incl. VAT) with only a couple £44/99 and a couple pre-orders at £52.99. In other words, Thermalright coolers priced at £80 are 2 to 3 times more than MSRP.Yeah a bit expensive but because of the free upgrade kit.. made that purchase ok.
I've bought two other cooler towers they never made any upgrade kits... So that is £80 now unusable on new systems. They're basically now a paperweight.
Please let us know what you think of it's once you get it installed. Then tell us again in about a year.1st time going to a AIO im very nervous hehe
Mines a Thermalright Hyper vision 360 ArGB black
Tell me about it, but the good thing is that a number of modern motherboards have an easily accessible button you can press to release that latch.I actually went for an AIO this time, but the reasoning had nothing to do with cooling ability. I was just tired of the absolute hassle, being unable to access the pcie retention latch, under my previous giant deepcool heatsink.
It's the main positive about them these days.
Haha same here, and its just the 120mm h80i then h80iv2. Upgraded my 3800X to a 5900X and its struggling a bit, thought about switching back to air (Noctua or PE) but I can't be bothered to take the MB out to swap the baseplate out. So I'm stuck. I need to bite the bullet and just upgrade everything. The only thing i'd keep would be the RTX4080. So next time maybe i'll get OCUK to build it. This Antec P180 case owes me nothing but its time for the skip!I have used two generations of Corsair AIO's without issue. Bit of a worrying read this thread though.
