I been playing since day one lol.That looks fine. It should just work.
Are you outside the prologue yet? I seem to remember you can't save during the whole of that (it goes on a long time)
I added a few more mods last night such as the easy blocking and counters and that seems to work.Not a clue.
The only thing I have different to you is I don't have a mod_order file in the base Mod folder. Although as you have only 1 mod there's not much to order
Did you install it manually or through Vortex? I did it manually.
And how the hell is the nude mod the top mod when sorted!?
The save mod still doesn't and yes I downloaded it manually.
Am I supposed to map the save button somewhere?
Unlimited saving 2 doesnt work. I tried manually adding it to the mods folder and pressing f5 doesn't save
I think you may be able to change it, open the USII.pak file with 7zip and in the libs\config\defaultprofile.xml there's a key bind, I haven't tried changing it myself though as it works fine for me. The only things other that I could think of is if your keyboard had a secondary function and the FN+F5 key workedI been playing since day one lol.
Pressing f5 doesn't do anything.
O wowNPC Overhaul
NPC Overhaul
Overhauls the appearance of all female NPCs, both major and minor ones. Also fixes seam errors on all women.www.nexusmods.com
Looking at the screenshots, I struggled to see any differences for the majority... there are some that stand out but most seem too simmilar.
- Verdant Vegetation – enhancing grass, trees, and foliage.
- Enhanced Common Furniture – Improves textures and materials of everyday furniture for added realism.
- Enhanced Street Decorations HD – Upgrades signs, banners, and other street details for a more lived-in world.
- Tasty Textures – Enhances food textures, making meals look more detailed and appetizing.
- Detailed Everyday Objects - enhances a wide range of everyday objects in the game world, bringing a new level of realism.
- Horse Equipment HD -significantly enhances the visual quality of all horse equipment in Kingdom Come: Deliverance 2.
- Landscape and Materials Overhaul
FPS Boost - Enable Async Compute - Conflict-Free
Enable Async Compute for rendering on high-end hardware without conflicting with other mods or requiring command line arguments! Bigger FPS boost on faster hardware.www.nexusmods.com
