OcUK RX9070 Series Review Thread
Caporegime
9 Nov 2009
Planet Earth
Asus
- RX9070XT
https://www.techpowerup.com/review/asus-radeon-rx-9070-tuf-oc/ - RX9070
https://www.guru3d.com/review/radeon-rx-9070-review/ - RX9070
https://www.guru3d.com/review/review-radeon-rx-9070-xt-reference-edition/ - RX9070XT
https://www.storagereview.com/review/asus-prime-amd-radeon-rx-9070-xt-and-rx-9070-review - RX9070 and RX9070XT
ASRock
- RX9070XT
https://www.pcgamesn.com/amd/radeon-rx-9070-xt-review - RX9070XT
Gigabyte
Powercolor
https://www.sweclockers.com/test/40749-powercolor-radeon-rx-9070-xt-red-devil-satan-vad-snabb - RX9070XT
https://www.sweclockers.com/test/40758-powercolor-radeon-rx-9070-hellhound-tyst-hund-biter-varst - RX9070
https://www.tomshardware.com/pc-components/gpus/amd-radeon-rx-9070-xt-review - RTX9070 and RX9070XT
https://pausehardware.com/test-amd-radeon-rx-9070-16go-gddr6-reaper/ - RX9070
Sapphire
- RX9070XT
- RX9070XT
- RX9070XT
https://www.eteknix.com/amd-radeon-rx-9070-amp-9070-xt-graphics-card-review/ - RX9070XT
https://www.hkepc.com/23247 - RX9070XT
https://www.guru3d.com/review/sapphire-nitro-radeon-rx-9070-xt-review/ - RX9070XT
https://pcper.com/2025/03/the-amd-radeon-rx-9070-and-rx-9070-xt-review-featuring-the-sapphire-nitro/ - RX9070XT
https://www.eurogamer.net/digitalfoundry-2025-amd-radeon-rx-9070-9070-xt-review - RX9070 and RX9070XT
https://www.club386.com/amd-radeon-rx-9070-review/ - RX9070
https://babeltechreviews.com/amd-rx-9070-and-rx-9070-xt-performance-review-the-new-budget-kings/ - RX9070 and RX9070XT
XFX
Group Test
Linux Test
FSR4 Test
Video Reviews
HUB comparing it in every chart to a 5070ti seems unfair considering the price difference!
So its basically a 7900XT/4070Ti Super at 1440p, few % faster at 4k and destroys the 7900xt/xtx in RT
I'm liking these numbers for the Nitro...
Sapphire 9070 XT Nitro
https://www.techpowerup.com/review/sapphire-radeon-rx-9070-xt-nitro/
Well I'm sold.
Was tempted by the 5070ti to replace my 4070ti as I want/need that 16GB VRAM but with the price difference between the 2, the 9070 XT is the clear winner.
So slightly faster than 7900XT but not as fast as 7900XTX is that the conclusion?
I don't think its worth upgrading 7900XT for then unfortunately, even though price is good.
Depends on whether you care about ray tracing or not. The 9070XT will make a noticeable difference here, as will upscaling, with FSR4 being limited to this new series for now.
You'll be able to get similar IQ to native on a 7900XT with FSR4 performance mode, and at much higher framerates. The caveat is that FSR isn't currently available in that many games.
Mixed results for me.
Productivity in blender was a shocker
Will check more but not as strong as I had hoped but having said that - it's a bargain if it can be had for £600
Not bad, double the performance of the 4060 ti (which can be had for £350), so if you grab the £570 one, that is +100% performance for +63% price.
Actually, the 9070 at £530 looks like a better option for me, a bit under double my 3060ti, but with much lower power requirements than the XT (I have a cube MATX case that doesn't get the greatest fresh air).
Not as fast as I expected but at it's price MSRP or close to MSRP it's a winner , will be interesting how far it can go overclocked
Only pulse at MSRP ? The other AIB I feel are over priced
Hub mentioned release day prices might not last and prices increase after , AMD originally wanted to price these more
