bet you he does@GhostDog1981 bet you don't hold your nerve![]()
Great reviews as expected, FSR4 looks close to parity with nV now.
Hotchie motchie.
To be clear, it is actually parity with DLSS3 CNN, which is amazing, but not quite matching DLSS4's Transformer though
A very big achievement for sure, finally both sides get a good upscaling solution
Also very early days, I suspect updates will continue to improve it, they have with PSSR on my ProBut the AMD cards are faster at a similar price-point in most games and have more VRAM so have to rely on upscaling less often.
Just watched the HW unboxed review for the 9070XT and performance seems a bit disappointing, basically a 4070ti super in raster at 1440p, a bit more at 4k but with 4070S RT, 4070ti supers were available last year for £650 so this is not a big win for AMD imo.
Yeah I don't need a new GPU right now but if the Nitro drops to £650 or less by the end of the year then I might grab one.Looks like £700 for the Niro+ is more or less confirmed
Well interesting hypothesis, but DLSS3 often looked better than TAA anyway and so with FSR4 you're gonna want to turn it on whenever it's available because it makes the image look better than TAA. So I'm not sure I agree with using upscaling less often, as upscalers have gotten better in image quality, I'm using them more and more regardless of the fps
I certainly wouldn't pay above MSRP for one.It depends on games
It's basically a range from a 5080 to 4070ti lol.
At £569 if you can get it it's good
The Nvidia cards like the RTX5070 are starting from a lower peformance base,so will need to dip into lower quality DLSS modes more often. The lack of VRAM will also affect the internal render resolutions.
So even if DLSS4 Transformer has the edge,there will be many times the RTX5070 will need to use a lower internal resolution in the first place,which negates any realworld advantage.
Performance modes with the transformer model has the same image quality as quality mode on the cnn model. So I'm not sure a 5079 using lower upscaling settings makes much of a difference either. I still say both cards should turn on upscaling whenever available for better image quality
Across all games tested at all resolutions, I have the RTX 5070 Ti having an 8 percent RT advantage over the 9070 XT - but the AMD card comes ahead in the value stakes as the 5070 Ti's MSRP is 25 percent higher. Meanwhile, the tables turn with the non-XT vs 5070 comparison, with AMD holding a 5.5 percent RT advantage over Nvidia. Aggregating raster and RT results together - again across all resolutions - 5070 Ti beats 9070 XT by just three percent, while the 9070 non-XT bests the 5070 by nine percent.
