Will a U.S. imported ATX power supply work safely in the U.K?
19 Jan 2007
Up a Tree
Hello,
Can anyone help please?
If I imported an ATX power supply from the U.S. will it safely work in the U.K?
I have read various threads while searching google and most seem to think that either the power supply will have an input voltage selector or it will be self switch and will work OK.
Is this correct, the power supply I would like to import doesn't have an input voltage selector, but upon reading the Cybernetics power supply rating for the power supply, it states 110V-240V, 50-60Hz frequency, so this make me think that it will be OK and is a self switch power supply and I just need a UK power supply cable, what do you think?
Am I safe?
Yes, it should work without any changes required, assuming you check the manufacturer spec.
I'd not recommend you buy a PSU from abroad though, as the model may not have been optimised for operation in the UK and you can have difficulty claiming the warranty.
This is correct.
The PSU is built and tested to handle a range of input voltages and output a specific range of voltages. It doesn't care where in the world you are, so long as you stay within the range it is designed for.
If you need more reassurance, the PSU will have declarations of conformity that you can download from the manufacturer or whoever has branded it. There will almost certainly be an EU and UK declaration in there given the voltage range.
The caveat about warranty still applies.
Thanks @Distracted :)
Thank you also for the other comments, I have bought other power supplies from the UK which have only included a two prong power cable, and worked safely with a UK power cable.
I have already ordered the power supply as I do not know when it will be available to purchase in the UK, hopefully it works, I will use a power supply tester first to see if it works correctly.
Just noticed on the page I bought the power supply from it has a global 10 year warranty :) .
Also checked the spare power supplies I have and they all state 110-240V, 50-60Hz.
So all being well I should be good to go.
Hello,
Am I safe?
If the power supply is labeled 110V-240V, 50-60Hz, it will work in the UK without adjustment—just swap to a UK-compatible power cable. Unless it's a very cheap unit (which might cut costs by requiring a manual voltage switch), you should be good to go, though such units are rare.
Thank you for all the comments, the power supply I ordered arrived yesterday, took about a week to arrive.
It is indeed labeled 110V-240V, 50-60Hz, so looks like I am good to go.
I can tell it's a quality unit as it weighs a ton.
What PSU did you buy? :eek:
ASRock Phantom Gaming PG-1300G
Especially for an RTX 5090 as it will shut off the power supply if the cables get too hot, so there will be no damage to either the card, power supply or cable :)
Just seen it's now available to buy in the UK for cheaper than I paid, not by too much, so don't feel too bad
That's interesting
But does it only detect cable heat
At the end that's plugged into the psu?
Or at both ends psu and gpu?
