12 is fine, especially with DLSS4 being a significant step forward in upscaling. There may be outliers but you should be fine with most titles.Ok , i understand, its enough 12gb vram for 2k ?
By TechPowerUp, it should provide a 25% boost. It’s not great, but it’s not terrible either. However, I wouldn’t upgrade solely for that reason.Its worth upgrade to RX 9070 XT from a RTX 4070 SUPER , for 2K resolution
Because they've sold out and are awaiting more stock?Why are there no cards available to buy on the store right now?
Its true amd gpu work better with a amd cpu ?
If i get 9070 xt dont work better with 9800X3D than 4070 super ?Considering AMD come out ahead with the X3D CPUs then yeah they do, but for the most part don't worry about it.
A lot of reviews out there use the 9800X3D as a base for their reviews so theres lots of data out there, but generally the 9700XT is a lot faster than the 4070 super.If i get 9070 xt dont work better with 9800X3D than 4070 super ?
At the very least, your card is more than enough to keep you going until we see what the higher-end AMD cards are like, and also wait for properly priced cards.
Yeah, it's been tough trying to get a GPU lately, with all the 4nm production being allocated to higher-value things like AI and memes.There are no higher-end AMD cards this time round. 9070XT is the top GPU aimed at the middle 5070/5070ti tier.
Where have you been hiding ?
