What GPU ..to play Fortnite in 1440p at 240FPS.?
11 Jun 2004
Middlesex, London
Hello all,
So I have started to get the bits together for my son's Gaming PC.
I would like advice on what GPU I should be looking for please - But I am on a budget.
We have 240Hz monitor - So what GPU(s) should I be looking for him ...to play Fortnite in 1440p at 240 please?
Thanks
my son as a 4070s. runs this game very well on a 240hz screen but i dont know his max fps
what CPU will he be using?
deepening on setting this shows anything from 60fps to 400fps
What cpu have you settled on? Its easier to compliment this and know the platform limitation i.e. AM4.
Thanks - I think 4070 will be out of budget.
I was hoping to spend around £200-£300 max on a GPU
You don't really want to use upscalers if you are after that 240hz every frame counts competiveness. If this is the case then a 1080p monitor would be better for shooters and you would not need such a meaty GPU (less expensive).
I understand that competitive shooters are best played at low detail if that helps, but maybe check in with your son on his plans
Something on the level of a 6700xt should be your budget then. As there is more nuanced detail that is lacking here it is hard to advise beyond that.
at 1440p 240fps? i didnt realize it was then light to run or do you run low settings
Correct, you can go to potato level details and its easy street. If your not wanting dips much below 240, and running native 1440p but do not want it to look potato that is an interesting discussion.
