RDP / VNC software?
Commissario
16 Oct 2002
In the radio shack
I use Microsoft Remote Desktop to connect to a a couple of Windows PCs and that's fine. Now I have a headless Mac mini running, it's just a minor faff having to click Finder, go, connect to server, connect, sign in, pick high performance and then finally get on.
Is there a third party app that doesn't cost £35 (like Jump Desktop) where I can set up both RDP and VNC connections?
RoyalTSX is very good and covers a wide variety of remote connections. The free version allows upto ten different connection profiles so plenty of scope to experiment
The interface is very ugly and I'm having a problem passing Mac control keys to the VNC connection into my Mac mini. If I do cmd-comma, it takes me into the settings of Royal TSX itself and if I do cmd-q, it tells me it's going to close the host app. I can't figure out how to get them passed through to the client.
You can just save the connection with high-speed already configured, that way you can just double-click on the short-cut? I also use Jump Desktop, but yeah, the cost isn't great.
Works pretty well. I have a folder in my Dock with all the common machines - whether VNC or RDP - in there, so I can select that, it expands, and hit the machine I want. Never thought to do it with Alfred! May have a look see at that.
I did think about setting up a workflow in Alfred but it's not even needed. Because it's a saved file, all I do is hit cmd-space, space, m (as it's the first letter of the file I saved) and hit enter.
