How to buy 5090FE
16 Jan 2010
Earth
As the title says. I know there have been dreadful supply issues from Nvidia but some people have managed to buy a 5090FE.
How do you do it? I won't buy AIB due to rip off pricing for decent models so how to go about getting the FE?
Any advice welcome.
With 3080fe release I joined telegram group to get alerted when they dropped it took me the second drop to able to buy one , maybe something similar you can join now for Fe drops ?
Wait for an alert to ping from notify website and other such websites or discord groups, don't have the link on me hopefully someone else can share it with you. Then you checkout, miss it by 20 seconds probably already too late.
I'd pay extra for aib this round because up to 600w through the FE's shrunk/smaller design=insane noise levels and waaaaay more likely to melt/fail over time.
The reviews didn't seem that bad to me tbh... and given the current price difference (£1,889 vs £2,600+) between the FE and AIB models you could run it undervolted and power limited to 450W or something and still be quids in on price : performance if you did want to keep a lid on noise or temps.
You need something to notify you that there has been a SKU change. Notify-FE is one option, there are also Discord and Telegram options. This just means that a stock drop is probably coming, typically in 15-60 mins.
Then you have to sit on the site ready to order. Dave2150 gave some great tips on this:
There is still an element of luck as it depends where in the refresh cycle you happen to be when stock actually drops. As a result, the notification tools can sometimes be slow to update and every second counts.
It's got a three year guarantee and next card with process and architecture upgrade should be two years max. Next gen all current 50 series cards will take a massive hit AIBs more so if £600 more expensive. 3080FE meets 2080ti moment.
It runs hotter and louder than AIBs, that's factual.
A higher temp melts before a lower temp...
Some of the 90FE thermal pics are horrific imo and summers coming...
Yes you can undervolt it to 4090 levels but it's not as if 4090s melting and taking out PSU's as well never happened...
Some AIBs are quieter and some are louder
The connector is the same on all the cards, so can melt on any
Show me melted connectors from somebody using an ATX3.1 PSU with an ATX 3.1 (H++) cable
Again, it's science fact that higher temps melt before a lower temp, and you've not convinced me aibs are louder either, maybe some are, but they must be taking the **** at this point if they indeed are louder than a very loud FE...
I've had a PSU and (unrelated) an Nvidia GPU catch fire in the past, therefore safety comes first, prefer keeping my house and everyone in it safe.
There has been reports of 3.1 melting therefore best aiming at the op you're last question as I was only giving a bit of advice, it's only an opinion, take it or leave it, not bothered.:thumbsup
Get lucky? I'm only half joking too really. Sign up to the many discords/tools which will ping you when stock goes live, and hope you're available to purchase when the ping comes through. Then it's just down to luck if you got the notice quick enough. The past two drops have been early morning if that's any indicator.
That's how I managed at 5090FE this morning.
Dropped at around 9:30 and had a script running in Firefox, that I'd got from a discord server.
