- 29 Aug 2010
- Cornwall
In fairness it only seems to reach up to the radiator, which is probably 27mm thick? (based on those fans being 25mm), so 298mm + 27mm = 325mm.Ok, My new GPU arrived. It's an Asrock Steel Legend.
Some pictures. Excuse the quality, I am not a good photographer!!
First the Box. I scratched it while opening.
Now after I installed it in my PC.
And finally, turned on.
As you can see it's a pretty tight squeeze. The dimensions on the websites are a little bit off. As I have 320mm of space there, that's according to my measurements and the Corsair website. The card is supposed to be 298mm but as you can see it almost fills the space!! It's bigger than the 6900XT that it's replacing, that's for sure.
Had no problems, apart from having to reinstall the AMD drivers after I put in the card. When it first booted up it was like it was running a really low resolution it was all out of focus and the mouse was stuttering around the screen like crazy. Thankfully a reinstall worked and it seems fine now.
Off to try it in VR now.
EDIT: Also, I have that case!
