- 2 Aug 2016
It will certainly narrow your focus which will let you determine what you’re interested in.Thanks for the info, that was very helpful and insteresting
Just like you, me getting away from being the "jack of all trades" and start specialising will be a good start.
It’s a massive step, and no safety buffer, which is why you can always start as a side hustle.
I am unaware of your circumstances, but do it for the right reasons. I.e. because you genuinely want to do it and think you can add value. Don’t do it because you hate your boss, or where you work.
Not sure of your work environment, or if you already know what ‘genre’ of IT you want to specialise in, but if you’re in a big company with lots of IT teams, ask to shadow them for a day, even if it means booking a days A/L to do it. If you’re in a more closed environment, and it sounds like you could be because you’re the jackmof all trades, then take some time out to analyse what you enjoy, even volunteer at local businesses/trusts and see if that gives you a different perspective. Also looks good on the CV.
You have to be determined and paitent, as much as it makes my wife crazy, she will admit (I think!!) that you can’t do anything without a plan. You HAVE to have a plan. Understand the plan will change, it will be delayed and won’t always go your way, but that’s why you change the plan. Even if it’s a couple of bullet points, it doesn’t need to be war and peace. For example: by 45 I want to do this, or that. And then plan back how you’re going to make that happen. I’ve always believed in having a plan, setting goals and on the whole, a positive attitude. I’m perhaps a bit too over the top in terms of planning/goals but from my humble upbringing, I’ve done alright so it doesn’t hurt.
