- 4 Jul 2006
Got a mixer tap for kitchen and it keeps dripping, different rates and you can get it to slow right down or stop by pushing the hot tap knob towards where the water comes out, here is an image of what the tap looks like, it may not be the exact one but the one that most looks like it and we cannot remember where it was purchased from.
Now, when its dripping you can get it to stop by either pushing the bit that pokes out towards the cold tap or pushing the flat surface on the left in the same direction, now the dripping is coming from where the water comes out not the tap itself.
The left knob feels looser than the right, does this sound like a simple worn valve that isn't closing properly or something wrong with the tap, when you get it to stop dripping and use the cold tap it can start dripping again until you mess with the hot tap like I mentioned, also if you try pushing the hot lever to the left away from the tap the dripping will increase and moving it closer to the tap will decrease it.
At this point im not sure if I want it to be the valve or the whole tap because apparently there is not a simple standard for taps.
Its also a pain in the backside as the hot tap is over the draining board so no clue how I am going to get the screw out and if I turn it into the on position then its close to the back wall instead of the draining board lol.
