I'd go Sapphire nitro + if you can get one at a decent price. You also have the benefit of invisible cabling on that one and a metal shell. All the sapphires will have quiet coolers - my Pure is, can't hear it.Looking to upgrade my 6700XT in the near future ,what model/make 9700XT is considered the best to get?
(Not ASUS ,as i refuse to pay the Asus tax)![]()
Just ordered a Sapphire Nitro plus RX 9070 XT.
Not due until next month!!!
But...birthday present to myself!
I did want the Asrock Taichi RX 9070 XT, but it is never in-stock. The Nitro seems pretty decent. Plus the build quality appears to be good from Sapphire, after briefly owning a Sapphire 7900XT.
I also like AMD GUI for their drivers. After using Nvidia for 21 years! Nvidia driver menu looks the same after 20 plus years! I know they will replace fully with the app at some point...
Isnt the Pulse one of the chunkier models? pretty sure its 2.5 slot thick with triple fans and pretty tall card.@Gibbo any indication of when you'll have more XT's in? I wanted a Pulse as the bulkier ones won't fit my case.
The Nitro+,but my Pulse is amazing so I would get that as it's the cheapestLooking to upgrade my 6700XT in the near future ,what model/make 9700XT is considered the best to get?
We have another large delivery of Sapphire Pulse, Pure and Nitro XT's arriving next week.
If all goes to plan we are also expecting Powercolor Reaper and the other models including new white cards end of next week.
All Asrock models should be back in stock in volume middle of April.![]()
it has the 12vhpwr connector, but given it’s not going to be pushing anywhere near as much power as the nvidia cards sup, I’m happy to give it a whirl (…and the warranty is there if it fries)Are the power plugs on the Nitro+ ok? I read they were the same as the dodgy Nvidia ones?
Can anyone confirm? Cheers.
It's a 600w rated plug with 350w running through it. It's perfectly fine.Are the power plugs on the Nitro+ ok? I read they were the same as the dodgy Nvidia ones?
Yeah its perfectly fine. 12vhpwr connector is actually brilliant on NITRO+ its so fool proof with its two-tone colour.It's a 600w rated plug with 350w running through it. It's perfectly fine.
With the Nitro+ for £684 from another vendor, I'm wondering with OCUK and others prcing them at £719+, is it just the tax dodging and unscrupulous staff practices that allow them to price it £35 lower or are they getting a better buy in price?
Mine was showing June and arrived this week on Monday so...*Being delivered late April/early May
That's a big stipulation to address, the card has only been out for 3 weeks and we're talking another 4-6 weeks for these to even be in hand.
