- 21 Jul 2005
- Officially least sunny location -Ronskistats
its a strange one, normally if you have a CPU bottle neck you would expect to see the CPU at 100%ish
the low clock speeds on the GPU is just because it dosent need to boost.
I had to monitor the individual threads and not the collective register that some of the monitoring tools use when it comes to the cpu. The complimentary indicator that your gpu is not getting used is checking its saturation %. Just because you cannot assume if the cpu is not 100% you are not bottlenecked. It will be hard on games because many of them do not use the multi-cores/threads well anyway.
