New pc or laptop advice
2 Jun 2018
Hi all
Firstly it's been a number of years since i built a pc myself so I'm not sure if i trust myself to do it, especially with what I'd likely pay for the parts and risk me messing it up so I've wondered if it's possible to get a prebuilt pc without too much mark up from the builders.
Budget between £1500-£2000 possibly buying about mid-May.
Main uses are my younger son (17 yo) gaming, various games, on a 32 inch 1080p curved monitor. Also i just edited and exported a gopro video from our recent holiday using the existing pc mentioned below. Admittedly it's 4k and 3hrs long but took 10 hours to export!
The current pc is really old, Ryzen 5 cpu, geforce 1060 gpu, 32gb ram. Main OS drive is an ssd and also has newer m.2 drive.
From a little research i think we're definitely looking for a 5070 ti and due to buying in about May hopefully the prices come down and stock gets better. Possibly with a newer AMD cpu.
Any thoughts and especially recommendations welcome, cheers, Marc.
If you've built one before you can do it again. In fact I think it is easier now because cases and parts are better designed.
For that budget I would go with a 9800x3d and AM5 platform with a 9070xt. You can get the 5070ti of course but it's a bit more expensive.
Edit: since you're only after 1080p as well, this will be overkill even but if you wanted to get a better screen later you could do.
Thanks mate.
I think we definitely want to stretch to the 5070 ti so the 9800x3d cpu?
Nice to get some confidence with my skills but you believe in them more than me
Personally, I think if you want to game then a desktop is going to give you far better value than a laptop. A fairly big case is easier than a small one, with less chance you find your gpu or cooler won't fit. If you build yourself, invest time in watching videos. I found it quite stressful building a machine a couple of years ago. I think it is easier than it used to be but plan carefully and think everything through twice. Check twice, put your cpu in the right way.
I think people who build regularly underestimate the number of things a newbie can not know.
I would think twice about top end GPU ( or CPU). If you only take a single 3 hour vid a year then does it really matter how long it takes to export? Do you really need your game settings maxed out?
Thanks for the info mate.
Yeah i agree we'll get more for our money going for a desktop.
My son's been a champ while all his friends have faster pcs he's just kept it to himself about being left behind and not moaned, only commenting sometimes it would be nice to be able to game a bit better so i want to do it for him.
My older son has a laptop that isn't powerful but is about 2 years old so slightly out performs the pc.
I can't see anything on OCUK within your budget that would include the desired 5070 Ti.
This is the closest I could get (note the spec changes):
My basket at OcUK:
  • 1 x AMD Ryzen - Monster Hunter Wilds Game Bundle (SKU: DIG-AMD-04648) = £0.00
  • 1 x OcUK Gaming Khopesh - AMD Ryzen 7 7700X RTX 5070 Ti Gaming PC (SKU: FS-124-OG) = £2,066.94
    • Case: 1 x Kolink Observatory Y Mesh ARGB Midi Tower Gaming Case - Black Window
    • Processor: 1 x AMD Ryzen 5 7600X Six Core 5.30GHz (Socket AM5) Processor - Retail
    • Memory: 1 x Kingston FURY Beast EXPO 32GB (2x16GB) DDR5 PC5-44800C36 5600MHz Dual Channel Kit (KF556C36BBEK2-32)
    • Cooler: 1 x Cooler Master MasterLiquid 360 Core II ARGB All In One Liquid CPU Cooler - 360mm
    • Graphics Card: 1 x *Build* Palit GeForce RTX 5070 Ti Gaming Pro OC 16GB GDDR7 Graphics Card
    • M.2 Solid State Drive: 1 x WD Blue SN580 1TB SSD NVME M.2 2280 PCIe Gen4 Solid State Drive
    • Operating System: 1 x Build Stock Microsoft Windows 11 Home Advanced - Systems
Total: £2,066.94 (includes delivery: £0.00)​
The great thing about AM4 is that you can do huge CPU upgrades for the same platform. So, you could potentially upgrade that instead.
My basket at OcUK:
£540 (incl. VAT)
£400 (incl. VAT)
£190 (incl. VAT)
£170 (incl. VAT)
FREE DELIVERY
£155 (incl. VAT)
£132 (incl. VAT)
£160 (incl. VAT)
£128 (incl. VAT)
£110 (incl. VAT)
£95 (incl. VAT)
Thanks mate.
Is there anything new i should keep in mind when building if i go that route? Anything new with windows, anything to do with the bios?
I've built maybe 3 pcs in the past and upgraded the first one many times years back but it's been that long a don't have much clue apart from the physical aspects like thermal paste, cable routing etc.
I'm also wondering. I realise the benefit of higher spec cpus and gpus if you want to pay more. But on a configurator i was just checking there's so many options that it's tempting to constantly go for a higher option, even down to the AIO. One was 120w tdp and was the 'suggested' one yet the further options went well over 250w tdp in which case it made me wonder if the 120w tdp was enough.
I've also not been on the scene sufficiently lately to know what's happening with cases now that optical drives and HDD cages most likely won't be needed, is there any specific case that is getting a lot of hype for practicality against price.
I think I'd also want a single 32gb stick so i could add a second 32gb later as it's unlikely that I'd need more than 64gb and 32gb world be enough to start with I'm sure.
My mind boggles
Not that I can think of.
You don't even need an AIO for the 9800X3D, a peerless assassin/phantom spirit can handle it fine, but the case (Lian Li 216) can support either option. TPU's review of the 9800X3D had it @ 65 watt average in games and 88 average in applications.
The Lian Li reviewed well, nothing wrong with it and £85 for the non-RGB version is reasonable (comes with enough stock cooling fans for almost all builds too).
Fish bowl cases are popular now, you could look at Antec's C5 ARGB which includes 7x120mm fans (makes it good value). Antec's Flux has been reviewing well too:
Not recommended. You'd lose performance by running in single channel and there's no guarantee the extra stick would run happily, even if it was the exact same model (because they may change the memory chips, among other things).
If you want 64GB, I'd just buy it now, or alternatively get a 48GB kit if you're not happy with 32GB.
having 2 teenage kids, 1 18 and 1 turned 16 a week ago....it doesn't take long for them to gravitate from simple games happy at 1080p to wanting a nuclear powered monster crushing 4k...I'd stick with a 9070xt...a better monitor can be next years present then..one thing less to think about
Just been looking at the 9070 xt gpu too. Seems to compare with the 5070 ti
They're pretty good against the 5070 Ti in raster, but they do lose in ray tracing and power efficiency. If you can get a 9070 XT at the price it is supposed to be, I'd take one, but the cards that are pushing 650-700 and higher are a harder sell if the 5070 Ti is reasonably priced. That said, I wouldn't pay £900+ or £1000 (ha) for a 5070 Ti either.
Still gathering my thoughts and options with this ready for a couple of months from now.
So i like the sound of an AIO over an air cooler mainly due to the bulky nature of the air coolers. Do they ever break and allow liquid into your components?
Also, i have a windows 10 licence on the existing PC, can this be transferred over to the new PC if i downloaded windows 11 on the new one? If not, What's the cheapest legal way to get windows 11 with a full license?
very rare, but it happens. if you want 100% reliability then stick with an air cooler (ie only the fan can fail)
with an aio, the pump can fail, the coolant can leak and the fan can fail, so more points of failure than an air cooler
we can sort this out when you get here :)
