- 7 Sep 2020
- Gods Country
so still 6k cheaper then.... if he digs the trenches himselfIt not though is it, the quote is for a further 11 panels on top and that 1k gone in panels alone.
You said you were quoted for a 13kw system tbh so that is what I compared it to. Even so I'm just showing you how expensive your quote is but it's your moneyIt not though is it, the quote is for a further 11 panels on top and that 1k gone in panels alone.
The Jemenergy quote says 11kw but 20x455 panels are 9kw. These are the same type of adverts I've tried and they don't really come in at that price after the site survey. The only one that did was the gypsies that quoted me and I'm not happy shelling out 20k to them.
Yeah to be fair to dandle that ad I showed is actually a bit misleading.The inverter is rated at 11kw
(Inverter Capacity: The Powerwall 3 has an inverter rated anywhere within a range of 3.68 kW to 11.04 kW)
Starting to consider this now based on the Ocotopus 0% offer triggered a passive interest and i now have two plug in vehicles so atleasyone would be at home to charge from solar. Its pretty apparent their quote is significantly more than other companies so far and also i think i may have a tricky roof install as i have a 3 story house and the top floor has sloped ceilings so the loft is very small and boxed in insulation on the rafters so cant really see the structure from inside.
Looking at hopefully 10 panels as my SW roof has two skylights![]()
Yes.Thanks, Is export on Intelligent Go 15p?
Battery and inverter would be on the exterior, no interest in loft mounted kitA friend has recommended same installer he had and GivEnergy looks the right sort of hardware and web dashboard im after so ill see how this goes.
My opinion is they are snake oil.
