totes lolYou guys and girls with solar panel must be loving this weather. Blue sky all week
Hey guys,
What 200W Solar panel would you recommend to pair with a 100V 20A MPPT ?
I've just backed out of buying the Renogy Solar Panel (Monocrystalline Silicon) and am looking for better options ?
Check spec for max over allowance and buy one to match that
Post a link to the model of MPPT your using, can probably use a much larger panel that 200w.
city plumbing have plenty of panels in that range, and cheaps as chips too
@Gammawolf pretty sure he only wants one panel, that controller won't take 3.
I have a Tesla Powerwall 3 and I'm thinking of installing solar panels. I have a south facing roof with space for 6 panels, south-west one for another 6 and a noth-east one for 4. The Powerwall has 3 imputs so I was thinking initially of getting 16 panels. But I spoke with a friend who said that only 4 panels on a string are a bad idea, because the voltage they generate would be too low. Is that the case? Do you think I'll be better off with 12 or 16 panels?
