- 4 Jul 2006
@Ron-ski This one, top is string inverter specs, bottom is 1x500w solar panel, info from midsummer.
aaahhhhhhh, I thought you added all the numbers up to come under what inverter could take.Not sure what the problem is. 15.86 A is less than 16 A so it's all good. Panels are (should be) in series so if you have 1 or 10 it's still 15.86 A short circuit. Only voltage adds up. With 560 V max you could fit 560 / 40.1 = 13 panels*.
*Edit: Should add there is a caveat with open circuit voltage where you could account for Voc when it's cold, because it will be higher. The data sheet will tell you how much it changes by. In this case it's probably not important because there's nearly 40 V of headroom.
I’m thinking you might be a neighbour of mine across the road as for years they’ve had pigeons trying to nest at the back of their satellite dish.We had one try to build a nest between the satellite dish and wall for about three weeks. All of the sticks just kept falling out. They're stubborn but thick aswell.
I solved the problem last year with bird spikes and we've had panels a couple of years now. I think pigeons are just universally thick.I’m thinking you might be a neighbour of mine across the road as for years they’ve had pigeons trying to nest at the back of their satellite dish.
If you’re currently having solar panels fitted then you’re definitely my neighbour.
Subliminal Aura, this quote above is all you need to know about preferred panels really. Just check the specs are to your inverters satisfaction.
pv output is a different thread.....Very vague isn't it - contrary to the Thread title
So much for " real world recommendations ", not much help in here and far too much PV output willy waving
Cya - will seek help elsewhere
we told him that and told him where to buy them and he still aint happy.....Jeez, the 'real world recommendation' that you seem to need your hand holding for in regards panels is basically any panel will do. The only real differences between them are price and output/size. Efficiencies are all virtually identical. Just buy whatever you can get for a good price in a size where you can fit the most on your roof.
And yes, the whole point of the other thread is to willy wave and post outputs, hence in a thread of it's own.
Also, i don't think anyone here is using a 12v car battery, so not sure you'll get any recommendations for that. The forum Ron-ski linked really is the place where all options will be discussed.
Personally I'd go with the Fox set up, its a known quantity in the UK and I'd have bitten my installers hand off a year ago for that price.I’ve had a quote, which I think is fairly reasonable considering but happy for people’s thoughts.
time for a roof-integrated system i'd sayIf you had a panel failure after say 10 years and it requires scaffolding, it may well workout better to replace the whole lot.
Back to business![]()
In regards to warranty, I wouldn't put too much emphasis on its value, the warranty isn't Apple Care, if you have a failure, it may or may not cost you money and how easy it will be almost depends entirely on your installers willingness to fix it. Once you are commissioned and have been up and running for a few months, the chances of a pre-mature failure is rare but the chances of your installer being around to claim off at the back end of that warranty is not high and the manufacturer warranty doesn't usually include labour, scaffolding and all that good stuff. The chances of the same kit being available at the back end of the warranty is slim and the newer kit may or may not work with your existing kit. If you had a panel failure after say 10 years and it requires scaffolding, it may well workout better to replace the whole lot.
Initially I want to build a system for trialling in the first instance
Thanks for the detail. I've not heard of Hanchu, and even though they seems to be selling on the `blade technology` of their battery systems which on paper seems good.
I'm going to get back to the company and see if there's other options for the battery/invertor as well as the two quotes seemed good, but I'd like to check if there's other options.
Also, happy to hear other recommendations for any systems, including Hanchu or Fox.
