Call of duty Black ops 6
So, the power drill. I thought the baseball bat was an exercise in frustration, it's literally an after dinner mint in comparison to this.....thing. I've read that it's glitched for KB&M and is fine with a controller, it's one of the last things left to do on Dark Matter (rocket launcher and baseball bat too) but I can't get any double kills, let alone triple etc. I've used tactical expert perk to spam smoke and also shock grenades to stun but no joy WHATSOEVER. I hate it more than the Goblin.
The drill and the bat are both very much patience testing weapons.
Assume you're trying to get the kills on Stakeout 24/7? Its the only map I found that can give you the kills you need, but you do go massively negative trying. I got the double kills on the drill (using KB&M), running down the centre of the map through the two windows and trying to get a bit of luck find those snipers, lmg, AR players distracted firing down through the staircase lobby. Failing that crouching/lying down down in the bedroom near the door and wait for single players to come running through (the bedroom without the duct to A is where I did a few).
Also I was dumb, I got the first 40 kills using the normal 2 hit kill attack, was trying to figure out why I couldn't do what other players were doing to me with that kill animation that stops you from firing your gun. Found out I could use the power attack for a one hit kill (RMB), obviously you're exposed while the animation is going as you are with take downs, but I found it a lot easier just running into players hitting my RMB and getting those kills.
Not done the triple kills yet though. May leave that till everything else is done as I still got a lot to do.
I was kinda resigned to dying A LOT doing the drill and the bat. Of course there is HC Stakeout and run around like a maniac for a one hit kill with the LMB, but I found that a heck a lot harder.
Ahhhh, thanks for this, much appreciated. I didn't realise there was a RMB attack, I assumed I was doing something wrong. I have been doing this on Stakeout so will see if I can not go 0.35 KD for once.
Can anyone explain why I was just killed by a Superi 46 but mine is locked and cannot selected it?
It shows permanently unlocked but has this yellow i symbol on it, along with all other weapons that are not black ops ones.
It seems that you need to specifically unlock it in BO6. If you go to Barracks>Challenges>Armoury and see what you need to do to unlock it. Although I've seen come people say it doesn't appear in the armoury. I don't play Warzone, so not much help sorry :(
From modern warfare 2 / 3 theres some random challenges for things like spears and hammers but nothing specific to say M4A1, MP5, Vel, Superi etc.
This is so annoying, BO6 keeps resetting my settings, keyboard binds and graphics. Apparently this is down to OneDrive, the only fix seems to be to turn off OneDrive sync on the Documents folder which I don’t want to do as I do use OneDrive to sync files. And MS in their infinite wisdom don’t allow me to exclude folders.
ARGH :mad:
So here's my fix, seems to be working so far. Delete the "Call of Duty" folder in Documents, create a text file, BO6.reg and add the text contained in the spoiler, then double click the file to open it and merge the changes in to your registry, then restart the computer. This will stop OneDrive syncing the files used to store settings in BO6, if you look inside the "Call of Duty" folder you will see they now have a grey No Entry sign.
Windows Registry Editor Version 5.00
[HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft\OneDrive\EnableODIgnoreListFromGPO]
"*.cdb"="*.cdb"
"keybinds.cod24.kb"="keybinds.cod24.kb"
"s.1.0.cod24.*"="s.1.0.cod24.*"
"g.cod24*"="g.cod24*"
"g.1.0*"="g.1.0*"
ARGH :mad:
I've been complaining about this for 2 months. Problem started around xmas time after a patch they did
Now got Dark Matter for all guns, launchers and specials. Just that damn power drill (Gold) and baseball bat (Diamond) left to do, both of them fun free.
What's the random time warp glitch graphics things with a floating orb then loads of swirling on the screen?
We were on Ribirth island and me and my teammate noticed it mid game. I thought my GPU was melting or something until he noticed the same!
Hopefully a stargate to Verdansk
Is anyone with an AMD GPU able to get the in game FPS limit to work correctly? I'm only able to cap at set numbers 100, 200 and 250 etc. If I set to anything in between it ignores and jumps to the higher number. Very odd. I'm trying to avoid outside limiters, Radeon chill, RTSS etc.
I'm gonna be playing today's new S3 zombies map and the new team cranked LTM, if anyone else is up for it.
rp2000
I'm having the same issue, if I set the in game limit to be 119 (just below my 120Hz refresh rate) but the game seems to hit 125 and it seems to flicker a lot too. If I set it to 100fps limit then it seems to limit it correctly and there seems to be way less flickering.
I've tried using the FPS limit in the AMD drivers and it doesn't do anything and I've tried Radeon Chill and that doesn't do anything either.
If you have a VRR display you should be setting it at least 3 frames below your refresh rate to prevent screen tearing, and also enable V-sync.
I ditched one drive and now sync with Google drive.
Does exactly the same with more free storage and non of the problems associated with one drive.
Does this work exactly the same as one drive then? Are there any negatives to doing this?
I tried it through the game itself and it seems to work and hold FPS at 141.
