- 30 Dec 2018
Hi there,
Been a long time since I posted anything, but wanted to check some other opinions before I decide on what to do next.
My partners PC is a build comprised of hand-me-downs from upgrades on my own PC, performance wise they're happy with it as they're not a major PC Gamer, however the thing sounds like a jet engine which makes me thing the AIO cooler is not up to scratch anymore and is on its way out.
It also has 2 Noctua fans (unsure which ones, but they're several years old now) which I believe also contribute to the insane amount of noise.
I've attempted changing settings in the BIOS and via software to try and mitigate the fans going full "fighter jet" but it doesn't seem to make a difference.
Any suggestions to either mitigate the noise or get some new components to improve the cooling would be very much welcome, see below for their current key parts (I'm omitting things like storage as its not really needed)
PC Specs:
CPU : Intel Core i9-7900X 3.3 Ghz 10-Core processor
CPU Cooler : Unsure on the make, but its a 2 fan AIO, came with an old OCUK bundle
Motherboard : Gigabyte X299 AORUS Gaming 7 Pro ATX LGA 2066 Motherboard
Memory : Kingston HyperX Predator 32 GB DDR4-3600 CL17
GPU : Gigabyte GAMING OC GeForce RTX 2080 Ti 11GB
PSU: Corsair 1000W platinum (unsure exact model)
Case: Lian Li PC-011 Dynamic ATX Full Tower Case ( OCUK Store Link )
As mentioned, my current suspicion is that the AIO it has is no longer performing well, I've re-pasted this before but the noise never subsided, so I currently feel replacing this AIO with a new one would be a good idea to reduce the noise as well as removing the old noctua fans and possibly replacing them with some low noise fans just to promote good airflow.
Things to consider:
My partner likes to keep their office warm, but a decent AIO shouldn't struggle that hard (its not a sauna, just warm) and the case has good access/flow from all sides (its not tucked into a corner with the sides covered etc)
PC Specs:
Things to consider:
