- 17 Mar 2025
- dorsetshire
That’s not really a good score. You need to look at your settingsbut it crashes at the like 17th run on that so yeah lol
I've got a Nitro XT and a box of beer, beer is getting the most attention.this is a solid grade A plan
what model of GPU do you have
-75mv +60mhz +10% power limit 2744mhz vram
only got a 750w psu atm but will be bunging a 1kw focus in there asap soon as i get around to it which might vaguely be the cause of that crash might be pushing the vram too far
i was at about 7100 or something out of the box
maybe
il give standard clock bigger undervolt and il try with the ram back up on the setting that gave the best in memtest which was 2744 anything past that and the throughput dropped like a stone im guessing because of error correction il try higher though might still help on the scores lol
the misses is a bit confused as to why im constantly making loads of noise in hte lounge running benchmarks constantly which is pretty funny tbh the rest of hte time its near silent but yeah lol
That's pretty much a stock XT score, so for a none XT it's very good.this is the best score i ever got with the 5700x3d, just did that now trying to push hard
Result not found
www.3dmark.com
this is:
+100 on the core
-85mv
+10 power linit
2882Mhz memory
if i change anything higher i just hard lock
Pretty good. You’re about 500 points above what I can get out of my pulse. It won’t go over 2750 on the memory. Though it does boost over 3.3ghz. My days of tinkering are over I was just trying this for a bit of fun. I’m going to just leave it stock I think.this is the best score i ever got with the 5700x3d, just did that now trying to push hard
Result not found
www.3dmark.com
this is:
+100 on the core
-85mv
+10 power linit
2882Mhz memory
Good score!! I think UV too much and it hinders scores too.Managed a much higher score with my Pulse 9070XT with your settings although had to back of the vram a bit to stop windows crashing and artifacting and UV to -70mv Settled on 2766mhz vram.
I think that tops this card out. Can’t get anything more out of it.
What other settings are you using?Managed a much higher score with my Pulse 9070XT with your settings although had to back of the vram a bit to stop windows crashing and artifacting and UV to -70mv Settled on 2766mhz vram.
Thanks I'll try it tomorrow to see if I can improve my score-70mv UV, offset core set at 0 vram fast timings 2766mhz and PL 10% with fans on 100%.
Get a refund and try a different card. These things happen.Update on my post the other day on my pc freezing with the steel legend 9070xt I had an issue this morning, not a black screen this time but a driver timeout and my game crashed with this information as a 141 Kernel event LKD_0x141_Tdr:6_IMAGE_amdkmdag.sys-PF:1-OC-HWS:1
Now my pc this time didn't crash, fully alive no having to turn it off or on again however it says amd again.. 4 issues in 3 weeks all pointing to amd, now this was clear as day as it literally said driver timeout and then showed in reliability monitor as a hardware error. Starting to think my graphics card albeit runs super fast, has issues or drivers have issues however 99% of you have no issues it would seem as reading through pages of forums.. I'm stuck because this happens every 5-7 days it seems a freeze or driver timeout or whatever and I'm like is my GPU Faulty, this hangs in the back of my mind when I game I'm anxious that it's going to **** the bed. I've never had to return a GPU before in my life after multiple pc's but all my issues point to AMD drivers or GPU. Really annoying me because in games like EFT that I love I'm getting great fps but my hot spot is 90c maybe that's the issue.. I brought my card from Overclockers so I'll guess I'll contact support or something. Really Pi**ed off
Edit: Sad state of affairs when I've got like 15 screenshots of hardware errors that all say AMD.. new £2000 pc is cooked, considering I play games and get crashes or now timeouts with no guess when they occur, simply lovely morning. Hope everyone's having a great weekend.
Have you reinstalled windows ? Sorry haven't been through post history. If yes then get it replaced. Maybe try another brand.Update on my post the other day on my pc freezing with the steel legend 9070xt I had an issue this morning, not a black screen this time but a driver timeout and my game crashed with this information as a 141 Kernel event LKD_0x141_Tdr:6_IMAGE_amdkmdag.sys-PF:1-OC-HWS:1
