OcUK PINNACLE CUSTOM 50 SERIES PERFORMANCE LAPTOPS
Gangster
OcUK Staff
16 Mar 2008
OcUK HQ
Hi All,
We’re excited to announce the launch of Pinnacle, a cutting-edge custom laptop brand now available exclusively at Overclockers UK! Designed for gamers, creators, and power users, our laptops combine premium performance, top-tier components, and unrivaled customization to deliver a truly personalized experience.
Whether you need desktop-grade power in a portable form, high-refresh displays for competitive gaming, or advanced thermal management for sustained peak performance, Pinnacle has you covered. Engineered for performance, durability, and style, these laptops redefine what’s possible in mobile computing.
Stay ahead of the competition – experience Pinnacle today at Overclockers UK!
The Pinnacle Custom Laptop is packed with premium hardware to optimise your gaming, streaming, and creating experiences . The Intel Core Ultra 9 275HX CPU is blisteringly fast and provides all the multi-tasking power you need for demanding AAA games and high-end applications. Plus, with a dedicated NPU, this processor is ready to efficiently handle AI workloads and free up the CPU for more important tasks.
To bring your gaming to life, the Pinnacle laptop pairs an upto NVIDIA GeForce RTX 5090 GPU with an 18” UHD 4K display or 18" QHD + display. The mobile-optimised graphics card is powered by innovative Blackwell architecture, harnessing the latest in DLSS, ray tracing, and neural shaders with upto 24GB GDDR7 VRAM to render your favourite games in crisp detail and with smooth frame rates. Plus, the 100% sRGB colour replication (X-Rite Pantone Colour Calibration Certified) and 200Hz/240hz refresh rate ensure peak immersion. Better yet, this gaming laptop can support up to four active displays (including built-in screen) to truly optimise your gaming set-up.
The Pinnacle is a custom gaming laptop, meaning you can adjust the base spec to best suit your needs just like with our custom gaming PCs. For the Pinnacle, you can configure the memory capacity, storage solution, and the operating system. These options are available to explore in the drop-down menus.
The memory can be a dual- or quad-channel system, utilising high-speed DDR5 SODIMM RAM modules. You can choose capacities up to 192GB, ensuring you have the memory solution to support your workflows.
For storage, there are four available M.2 slots, and each can support up to 8TB NVMe PCIe 4.0 SSDs with a max capacity of 32TB. One slot is compatible with PCIe 5.0, so you can take advantage of the lightning fast read and write speeds this standard provides.
Finally, you can choose between Windows 11 Home or Pro for your operating system.
Two Year Warranty​
The Pinnacle Custom Laptop is covered by a comprehensive two year warranty (1 Year Battery), for that extra peace of mind. This covers manufacturing defects, hardware malfunctions, technical support, and even free repairs. If you have any queries, please get in touch with our customer support team who are ready to assist.
UHD Screen
Pinnacle 5090 18" UHD 200hz Intel Core Ultra 9 275HX Custom Laptop
Pinnacle 5080 18" UHD 200hz Intel Core Ultra 9 275HX Custom Laptop
Pinnacle 5070 Ti 18" UHD 200hz Intel Core Ultra 9 275HX Custom Laptop
QHD Screen
Pinnacle 5090 18" QHD+ 240hz Intel Core Ultra 9 275HX Custom Laptop
Pinnacle 5080 18" QHD+ 240hz Intel Core Ultra 9 275HX Custom Laptop
Pinnacle 5070 Ti 18" QHD+ 240hz Intel Core Ultra 9 275HX Custom Laptop
Each of the above is defaulted to Corsair 32GB Memory and 1TB Gen4 M.2 storage.
They go all the way up to WD SN850x 8TB per slot and 96GB Corsair Vengenance per dual kit (192GB total)
Next Day Delivery Laptops
OcUK Pinnacle RTX 5070 Ti, 32GB, 18" QHD+ 240Hz, 2TB, Intel Ultra Core 9 275HX Gaming Laptop - £2299.99 Inc Vat
OcUK Pinnacle RTX 5070 Ti, 32GB, 18" UHD 4K 200Hz, 2TB, Intel Ultra Core 9 275HX Gaming Laptop - £2399.99 Inc Vat
OcUK Pinnacle RTX 5080, 32GB, 18" UHD 4K 200Hz, 2TB, Intel Ultra Core 9 275HX Gaming Laptop - £2799.95 Inc Vat
OcUK Pinnacle RTX 5080, 64GB, 18" UHD 4K 200Hz, 2TB, Intel Ultra Core 9 275HX Gaming Laptop - £2899.99 Inc Vat
OcUK Pinnacle RTX 5090, 64GB, 18" UHD 4K 200Hz, 2TB, Intel Ultra Core 9 275HX Gaming Laptop - £3399.95 Inc Vat
OcUK Pinnacle RTX 5090, 64GB, 18" QHD+ 240Hz, 2TB, Intel Ultra Core 9 275HX Gaming Laptop - £3399.95 Inc Vat
OcUK Pinnacle RTX 5090, 96GB, 18" QHD+ 240Hz, 4TB, Intel Ultra Core 9 275HX Gaming Laptop - £3599.95 Inc Vat
OcUK Pinnacle RTX 5090, 96GB, 18" UHD 4K 200Hz, 4TB, Intel Ultra Core 9 275HX Gaming Laptop - £3699.95 Inc Vat
A preview of the laptop.
FIRST REVIEW IS IN click here
£2,350 (incl. VAT)
£2,300 (incl. VAT)
FREE DELIVERY
£2,700 (incl. VAT)
£2,600 (incl. VAT)
FREE DELIVERY
£2,800 (incl. VAT)
£2,700 (incl. VAT)
FREE DELIVERY
£3,400 (incl. VAT)
£3,300 (incl. VAT)
FREE DELIVERY
What bits can we upgrade at a later point? SDDs? RAM? CPU?
How easy are they to maintain and how easy is it to get replacement parts?
Such as the battery as that's probably something that needs replacing on a lot of laptops?
Does it have a dedicated charging port or does it use a USB-c connector? How easy is that to replace?
What are the hinges like? I've on some laptop the hinges can give out (I think because they glue or screw metal hinges into plastic)
SSDs and RAM only
Faults we will deal with. Adding parts you have to remove the back cover to get access to the SSD's and RAM.
We will replace in the 1 year warranty but we have access to buy batteries to sell if outside of warranty or a backup is required. You just need to remove the back cover to replace.
It has it's own dedicated power port at the rear of the laptop. If this is damaged we can try and help with getting this repaired. We will hold a limited number of spare parts but we can't hold everything unfortunately. The laptops have a service center in the UK for anything we can't do in house.
The hinges are metal and covered by plastic. The cover for the hinge is pretty solid these days compared to past models.
SSDs and RAM only
Thanks for taking the time to answer these.
I didn't think the CPU would be upgradeable, but being a highend machine I thought maybe.
When asking about servicing and parts I'm mostly thinking about when it's out of warranty as it's an expensive bit of kit to throw away if it breaks after the warranty is up (and I'm thinking battery, charging port and hinges are the most likely to wear out and possibly the keyboard).
A little disappointing that the battery, something that is almost guaranteed to need replacing at some point, only has a 1 year warranty.
On the older versions of the laptops the CPU's could be changed but the issue was when supply of the CPU's stopped you would end up with loads of chassis you can't use. They now implement the GPU and CPU into the board and we have to pick which versions we want.
Outside of warranty we can still probably help you with parts but we would have to charge for the parts. I would have to find out if customers are able to buy direct from the service center but this has not been mentioned before. Looking inside the laptop most parts can be swapped pretty easy if you are experienced in these things.
The 1 year warranty on the battery could be the reason why some of the other brands only offer a 1 year warranty total.
We are working on it. We have just finished testing them thoroughly ourselves to make sure the max we can do with them. Our test laptop is using 32TB and 192GB with a 5090.
We have 5080 and 5090 units currently in stock with 5070 Ti expect in stock in the next few days.
We will have 5070 Ti pre-built options available in the next 1-2 weeks so it would be quicker to order custom on that line.
I need a new dev laptop and could happily test one for you to see how it handles multiple containers, cosmos DB, visual studio, vscode, rider.. ? :D
I'll write a review and everything..
Nice to see custom Clevo options back again although it would be cool if there were more options available on the accessories and warranty.
No mention if the platform they are running on supports the faster CSO-Dimm (not obvious from the configurator on what memory speeds are beyond a couple showing 5200Mhz)?
Good to see TB5 and presumably PS3.1 allowing for north of 100w over USB-c (should be up to 240w but very much platform dependant).
I think the intel ultra chips can’t take much faster memory
We found that memory won't run at the speeds it stats due to capacity of the CPU's. It will be the same for others using the CPU's as well. We removed the speed as all the memory is 5200Mhz for compatibility, we just wanted to list a couple of brands and prices so the customer had options rather than forcing a brand they don't like and also budget.
I have one of the 5090 versions of these on the bench at the moment (Not Pinnacle version) and its a pretty meaty bit of kit. Looks pretty good and the performance is pretty insane for a laptop. I do note that OCUK dont appear to offer Gen5 NVMe and i cant blame them to be honest as even though there is one Gen5 slot those drives can get pretty toasty. I have sourced some nice slimline heatsinks but i dont even think they will stave off much throttling if used in a productivity environment.
Screen looks amazing (Even with the odd resolution)
Memory, Like Robbie_G says is a pain to lock down compatibility, especially when all 4 slots are populated (I believe we have landed on 192Gb 5200Mhz max as well)
Nice bit of kit, massive overkill for gaming but some people will go all out. Its an insane price, but i wont tell people what to spend their money on. For productivity its very impressive as a desktop replacement product. I have had seen other resellers advertising these maxed out as mobile server products. (Although they had done similar with several previous version)
Oh and finally, as always with these mad powered laptops dont expect the battery to last much more than an hour and half when playing.
Our team have created a little video to show you one of our Pinnacle laptops. This open box video shows the full spec version with 4K screen, 5090 24GB, 192GB RAM, 32TB storage and Intel Core Ultra 9. With the custom laptops we currently offer the ability to change the colour of the logo and we are working on other pieces of artwork that can be printed onto the cover.
Currently high end only we will be looking at other models soon but for the moment we are targetting a little on the bigger stuff.
