Do i just loosen the top cap and stem bolts? and twist them 180 degrees? mines in the steep angle at moment... just wanna see what the slacks like.The plastic cups that hold the bearing have a notch at the front and the rear, rotate them around at the top or bottom etc to get your desired head angle. The notch will always need to face forward but as you have one on the front and rear, rotating just makes one a rear and the other a front and then the other way around once turned 180 degrees.
I have no idea what mine is currently set to although I think I have a steep angle at the moment. Ill check when I can mind.
