- 22 Nov 2007
Kolink's bronze units are pretty dire, not the worst but not what I'd expect to be promoted by a prominent computer outlet like OCUK.
Their gold and platinum aren't terrible, some review well, but they're middling at best and lack the warranty compared to similarly priced and higher quality competitor platforms. I'd not be too concerned as if the PSU has worked well for you this long it probably will for some time to come.
"Gold rated" doesn't mean as much as people tend to think either, it's simply an efficiency rating. You could have PSU that's technically highly efficient but a fire hazard that could blow your entire rig out if it died, there's higher quality bronze units (aka less efficient) on the market than some gold rated. Honestly the whole efficiency standard thing borders on a marketing scam, you see massive premiums for platinum units but the amount of energy saved over a gold would never save you enough in electricity bills to be worth it for the extra cost.
Pretty sure this is the one i have.
Kolink Regulator 1000W 80 Plus Gold Gen5 Modular Power Supply
Order Kolink Regulator 1000W 80 Plus Gold Gen5 Modular Power Supply now online and benefit from fast delivery.
I trust OCUK as they build thousands of machines a year and they wouldn't keep using a part if they were constantly having to fix/replace them. Knowing better though i probably would go with a more reputable brand for my next build.
