4x Longi Hi-Mo X6 615w panels |
Longi Solar Hi-MO X6 Max 610WP PV Module LR7-72HTH-610LONGi new generation HPBC cell technology opens a new chapter in the mass production of high-efficiency cells and continues to lead the reform of the industry.The efficiency of LONGi HPBC cells exceeds 25.0%.The efficiency of the PRO version HPBC cells exceeds 25.3%.
![]() | £82.30 X 4 = £329.20 |
4x Mounting kits |
![]() Adjustable Angle Solar Panel Mounting Brackets Solar Panel Tilt Mount Bracket 1x | eBayThe solar panel stand is suitable for all solar panels of all sizes. The solar panel holders are best suited for mounting solar panels on facades or flat roofs. These can also be mounted on any solid surface.
www.ebay.co.uk
| £19.42 X 4 = £77.68 |
1x 6mm cable spool (50M) |
Cable World Pv Solar Cable H1Z2Z2-K 6.0mm Black -40°C/+90°C 50M ReelH1Z2Z2-K Solar Cable is TUV and EN certified and designed for the connection of photovoltaic panels. This extremely versatile single conductor cable is designed to meet the varying needs of the solar industry. Highly flexible, compatible with all brands of connectors and suitable for wet, damp...
![]() | £55.72 |
10x MC4 connector pairs |
Cable World Male and Female MC4 Connection Pack CWMC4This pack contains both Male and Female Connectors for PV systems.
![]() | £2.30 X 10 = £23.00 |
TOTAL | £485.60 |
Noted.As its a Solaredge inverter you will need SolarEdge optimisers.
You'll need to research how to add panels to it, you may need to involve your installer, especially if you want to update the layout in the app of Web dashboard, I don't think an end user can do that.
but yet the unit cost is pegged to the price of gas and the uk still has one of the highest prices in europe![]()
Grid prepares for record low demand this summer due to solar boom - Energy Live News
NESO says demand levels could fall to as low as during the pandemic summer of 2020www.energylivenews.com
Until they drop the export rate because of it...![]()
Gonna be a good summer![]()
Aren't those like a 1 year contract or they can change any time?
I am in the process of leaving my fit export to go octopus export as it pays over double.
