Have you consider a streamer instead of a separate DAC and AMP combo? So a WiiM Amp Pro for example, or something from Bluesound (POWERNODE)?
Well this is pretty much the most useful reply I've ever received on these forums! Thank you VERY much for all the detail, it's fantastic!Hey there manic111.
[Snip]
Have you consider a streamer instead of a separate DAC and AMP combo? So a WiiM Amp Pro for example, or something from Bluesound (POWERNODE)?![]()
Dali
- £200 – Dali Spektor 1 – 14.0cm W x 19.5cm D x 23.7cm H. [Mfr link]
- £250 – Dali Spektor 2 – 17.0cm W x 23.8cm D x 29.2cm H. [Mfr link] Comments: width creeping up a little.
- £400 – Dali Oberon 1 – 16.2cm W x 23.4cm D x 27.4cm H. [Mfr link]
- £700 – Dali Opticon 1 Mk2 – 15.2cm W x 23.1cm D x 26.1cm H. [Mfr link] Comments: these look excellent, and are pleasingly compact at only 15.2cm wide.
- £1100 – Dali Menuet – 15.0cm W x 23.0cm D x 25.0cm H. [Mfr link] Comments: price is spiralling, but these are extremely nice. Brilliantly compact, at only 15.0cm wide.
- £1300 – Dali Menuet SE – 15.0cm W x 23.0cm D x 25.0cm H. [Mfr link] Comments: price really spiralling upwards here, but these look like stunning compact passive speakers. Out of all the speakers on the list, these are really appealing to me right now, and are my current “final pick”.
I have one of those streamer things even more bizarrely when I connect my GPU to it on the display it shows me what GPU I haveInteresting suggestion there Firegod, and many thanks for posting it.
I had not considered that!
I'll take a look into those options when I get some free time, for sure.
No worries - just throwing it out there. Might not be what you are after.Interesting suggestion there Firegod, and many thanks for posting it.
To the best of my understanding, running active studio monitors means that only a DAC is required on the desktop. (As opposed to the need for a DAC plus an AMP for passive speakers.)
While it does vary between the brands, Active speakers, rather than powered, can actually sound cleaner (for want of a better word) than equivalent passive + amp.Out of interest, and not because I'm recommending it but because I am also trying to redo my desktop audio (at a far lower level of quality than you), why are you not considering active speakers? Is the quality significantly worse?
I only ask because I'm considering getting some at present, but if an amp and passive are the way to go then I could easily be persuaded!
What I think of as active speakers generally have an amp per driver inside each speaker, whereas I think of powered as more like having a mini amp inside one speaker with an audio only cable to the unpowered one.
