Lounge door had been re-hung and butchered a bit so cut some shims and filled for a first pass. A bit rough but will fill and then sand when it's eventually repainted. Less ghastly to look at for the time being anyway.
Cheap cast iron rad popped up on marketplace (£50) so quickly fashioned a stretcher out of some 2x4 so that it could be laid down and slid into the boot over MDF, before being strapped down. Blocks of wood pictured were placed beneath the stretcher so it could be picked up easily. 'Only' 90-100kg this one
, which is considerably lighter than the one in the lounge.
Needs a bit of TLC and a respray, will pressure test and replace the bushes and seals.
