Ultrasonic Record Cleaning Machines?
16 Jun 2004
Hi
I am thinking of getting one of these and am wondering if anyone here has any experience of them?
They all seem to come recommended but vary in price from about £400 for a Humminguru to a few £1000!!!
I recently got the Humminguru and it has impressed me greatly
Thanks for reply. Can I please ask in what way it has impressed? I don’t doubt that it will clean records well, but would you say you notice an improvement in sound quality after a clean?
I actually use the Humminguru Nova machine, which isn't £400 but about £800 by the way.
There are a number of things that any potential owner should be aware of though, when you first buy the machine, make shure you order spare water filters and spare air filters at the same time.
It's also a good idea to order a spare water tank, just in case you decide to use Ethenol or PVA as cleaner.
One thing to be aware of is that the Humminguru does not have a rinse cycle. Does this matter you may ask, yes it does. It's well known that records benefit greatly from a rinse in distilled water after any cleaning cycle (manual or Ultrasonic). They also sound better after a rinse cycle as well, they can still go back in the Humminguru to be dried.
In my case i simply use a Disco Antistat filled with distilled water to rinse off after Ultrasonic cleaning.
I will say though that i have about 2500 LP's, so the cost of this type of cleaning is worth it to me. Unless you have quite an LP collection, you may well find a Disco Antistat more cost effective than even the cheapest Ultrasonic route.
Thank you for a very informative reply. I have well over 1000 LP’s so I think I could justify the cost,
Thanks for replies. I think I’ll invest in one. It’s good to know about the reduction in static as my record player is in a bedroom and with a dog running around it’s very dusty!!!
I'm interested in this, too. But for me it needs to be a cleaner that can accomodate 78 shellac records, too. Obviously there's lots of research to be done, but even with a mild cleaning solution I'm not sure the ultrasonic action would be good for them.
Ultrasonic machines should be kept well away from shellac records. The problem isn't so much the solution but the cavitation rate of the machine being used.
The Humminguru for instance is 40Khz, where as the Degritter is 120Khz. The 40Khz machines have much larger cavitation bubbles than the 120Khz machines, not a huge problem for Vinyl. But for a very brittle substance like 75 year old shellac, the risk of even the 120Khz machines shattering the record is very real.
Thanks for informative post, thankfully I don’t have any shellac records… but a friend of mine, whose records I would offer to clean might have! You could well saved my bacon there!!!
